Staging: comedi: Use function setup_timer for combining initialization
Author: Somya Anand <somyaanand214@gmail.com>
The function setup_timer combines the initialization of a timer with the
initialization of the timer's function and data fields.
So, this patch combines the multiline code for timer initialization using the function
setup_timer. This issue is identified via coccinelle script.
expression E1, E2, E3;
type T;
- init_timer(&E1);
- E1.function = E2;
- E1.data = (T)E3;
+ setup_timer(&E1, E2, (T)E3);
- E1.data = (T)E3;
- E1.function = E2;
- E1.function = E2;
+ setup_timer(&E1, E2, 0);
Signed-off-by: Somya Anand
 drivers/staging/comedi/drivers/das16.c   | 5 ++---
 drivers/staging/comedi/drivers/jr3_pci.c | 5 +----
 2 files changed, 3 insertions(+), 7 deletions(-)
diff --git a/drivers/staging/comedi/drivers/das16.c b/drivers/staging/comedi/drivers/das16.c
index be6277a..f66db97 100644
--- a/drivers/staging/comedi/drivers/das16.c
+++ b/drivers/staging/comedi/drivers/das16.c
@@ -935,9 +935,8 @@ static void das16_alloc_dma(struct comedi_device *dev, unsigned int dma_chan)
 	devpriv->dma = comedi_isadma_alloc(dev, 2, dma_chan, dma_chan,
 					   DAS16_DMA_SIZE, COMEDI_ISADMA_READ);
 	if (devpriv->dma) {
-		init_timer(&devpriv->timer);
-		devpriv->timer.function = das16_timer_interrupt;
-		devpriv->timer.data = (unsigned long)dev;
+		setup_timer(&devpriv->timer, das16_timer_interrupt,
+			    (unsigned long)dev);
diff --git a/drivers/staging/comedi/drivers/jr3_pci.c b/drivers/staging/comedi/drivers/jr3_pci.c
index 81fab2d..282c37f 100644
--- a/drivers/staging/comedi/drivers/jr3_pci.c
+++ b/drivers/staging/comedi/drivers/jr3_pci.c
@@ -706,8 +706,6 @@ static int jr3_pci_auto_attach(struct comedi_device *dev,
 	if (!devpriv)
 		return -ENOMEM;
 	ret = comedi_pci_enable(dev);
 	if (ret)
 		return ret;
@@ -775,8 +773,7 @@ static int jr3_pci_auto_attach(struct comedi_device *dev,
 		spriv->next_time_max = jiffies + msecs_to_jiffies(2000);
-	devpriv->timer.function = jr3_pci_poll_dev;
+	setup_timer(&devpriv->timer, jr3_pci_poll_dev, (unsigned long)dev);
 	devpriv->timer.expires = jiffies + msecs_to_jiffies(1000);
 	add_timer(&devpriv->timer);
BtrLinux
Privacy Overview
