Staging: dgap: Use setup_timer to combine initialization
Author: Somya Anand <somyaanand214@gmail.com>
The function setup_timer combines the initialization of a timer with the
initialization of the timer's function and data fields.
So, this patch combines the multiline code for timer initialization using the function
setup_timer. This issue is identified via coccinelle script.
expression E1, E2, E3;
type T;
- init_timer(&E1);
- E1.function = E2;
- E1.data = (T)E3;
+ setup_timer(&E1, E2, (T)E3);
- E1.data = (T)E3;
- E1.function = E2;
- E1.function = E2;
+ setup_timer(&E1, E2, 0);
Signed-off-by: Somya Anand
drivers/staging/dgap/dgap.c | 3 +--
1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/staging/dgap/dgap.c b/drivers/staging/dgap/dgap.c
index cea5b26..6766d5a 100644
--- a/drivers/staging/dgap/dgap.c
+++ b/drivers/staging/dgap/dgap.c
@@ -7039,8 +7039,7 @@ static int dgap_start(void)
/* Start the poller */
spin_lock_irqsave(&dgap_poll_lock, flags);
- init_timer(&dgap_poll_timer);
- dgap_poll_timer.function = dgap_poll_handler;
+ setup_timer(&dgap_poll_timer, dgap_poll_handler, 0);
dgap_poll_timer.data = 0;
dgap_poll_time = jiffies + dgap_jiffies_from_ms(dgap_poll_tick);
dgap_poll_timer.expires = dgap_poll_time; |
