staging: comedi: dt3000: remove unneeded variable
Author: Chase Southwood <chase.southwood@gmail.com>
Coccinelle (using scripts/coccinelle/tests/doublebitand.cocci) found this
assignment because 0 is or'd twice.  Upon inspection, I found that the
variable "mode" is only assigned once and used once, and thus can be
cleanly removed.  This patch plugs its value straight into writew() and
then removes the variable.
Signed-off-by: Chase Southwood
Reviewed-by: Ian Abbott
Cc: H Hartley Sweeten
 drivers/staging/comedi/drivers/dt3000.c | 4 +---
 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/staging/comedi/drivers/dt3000.c b/drivers/staging/comedi/drivers/dt3000.c
index 56e21cc..176a7ee 100644
--- a/drivers/staging/comedi/drivers/dt3000.c
+++ b/drivers/staging/comedi/drivers/dt3000.c
@@ -488,7 +488,6 @@ static int dt3k_ai_cmd(struct comedi_device *dev, struct comedi_subdevice *s)
 	unsigned int chan, range, aref;
 	unsigned int divider;
 	unsigned int tscandiv;
-	unsigned int mode;
 	for (i = 0; i < cmd->chanlist_len; i++) {
 		chan = CR_CHAN(cmd->chanlist[i]);
@@ -513,8 +512,7 @@ static int dt3k_ai_cmd(struct comedi_device *dev, struct comedi_subdevice *s)
 		writew((tscandiv & 0xffff), dev->mmio + DPR_Params(4));
-	mode = DT3000_AD_RETRIG_INTERNAL | 0 | 0;
-	writew(mode, dev->mmio + DPR_Params(5));
+	writew(DT3000_AD_RETRIG_INTERNAL, dev->mmio + DPR_Params(5));
 	writew(aref == AREF_DIFF, dev->mmio + DPR_Params(6));
 	writew(AI_FIFO_DEPTH / 2, dev->mmio + DPR_Params(7));
BtrLinux
Privacy Overview
