isdn/bas_gigaset: use USB API functions rather than constants
Author: Himangi Saraogi <himangi774@gmail.com>
This patch introduces the use of the function usb_endpoint_num.
The Coccinelle semantic patch that makes these changes is as follows:
@@ struct usb_endpoint_descriptor *epd; @@
- (epd->bEndpointAddress & \(USB_ENDPOINT_NUMBER_MASK\|0x0f\))
+ usb_endpoint_num(epd)
Signed-off-by: Himangi Saraogi
Acked-by: Julia Lawall
Acked-by: Tilman Schmidt
Signed-off-by: David S. Miller
drivers/isdn/gigaset/bas-gigaset.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/isdn/gigaset/bas-gigaset.c b/drivers/isdn/gigaset/bas-gigaset.c
index b7ae0a0..aecec6d 100644
--- a/drivers/isdn/gigaset/bas-gigaset.c
+++ b/drivers/isdn/gigaset/bas-gigaset.c
@@ -2365,7 +2365,7 @@ static int gigaset_probe(struct usb_interface *interface,
endpoint = &hostif->endpoint[0].desc;
usb_fill_int_urb(ucs->urb_int_in, udev,
usb_rcvintpipe(udev,
- (endpoint->bEndpointAddress) & 0x0f),
+ usb_endpoint_num(endpoint)),
ucs->int_in_buf, IP_MSGSIZE, read_int_callback, cs,
endpoint->bInterval);
rc = usb_submit_urb(ucs->urb_int_in, GFP_KERNEL); |
