staging: brcm80211: use kzalloc()
Author: Thomas Meyer <thomas@m3y3r.de>
Use kzalloc rather than kmalloc followed by memset with 0
This considers some simple cases that are common and easy to validate
Note in particular that there are no ...s in the rule, so all of the
matched code has to be contiguous
The semantic patch that makes this output is available
in scripts/coccinelle/api/alloc/kzalloc-simple.cocci.
More information about semantic patching is available at
http://coccinelle.lip6.fr/
Signed-off-by: Thomas Meyer
Acked-by: Roland Vossen
 drivers/staging/brcm80211/brcmfmac/dhd_sdio.c | 4 +---
 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/staging/brcm80211/brcmfmac/dhd_sdio.c b/drivers/staging/brcm80211/brcmfmac/dhd_sdio.c
index 53d4825..7632a0e 100644
--- a/drivers/staging/brcm80211/brcmfmac/dhd_sdio.c
+++ b/drivers/staging/brcm80211/brcmfmac/dhd_sdio.c
@@ -5644,14 +5644,12 @@ brcmf_sdbrcm_chip_attach(struct brcmf_bus *bus, u32 regs)
 	BRCMF_TRACE(("%s: Enter\n", __func__));
 	/* alloc chip_info_t */
-	ci = kmalloc(sizeof(struct chip_info), GFP_ATOMIC);
+	ci = kzalloc(sizeof(struct chip_info), GFP_ATOMIC);
 	if (NULL == ci) {
 		BRCMF_ERROR(("%s: malloc failed!\n", __func__));
 		return -ENOMEM;
-	memset((unsigned char *)ci, 0, sizeof(struct chip_info));
 	/* bus/core/clk setup for register access */
 	/* Try forcing SDIO core to do ALPAvail request only */
 	clkset = SBSDIO_FORCE_HW_CLKREQ_OFF | SBSDIO_ALP_AVAIL_REQ;
BtrLinux
Privacy Overview
