pseries/iommu: Add missing kfree
At this point, window has not been stored anywhere, so it has to be freed
before leaving the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
@exists@
local idexpression x;
statement S,S1;
expression E;
identifier fl;
expression *ptr != NULL;
x = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
     when != if (...) { <+...kfree(x)...+> }
     when any
     when != true x == NULL
x->fl
if (x == NULL) S1
if (...) { ... when != x
               when forall
 return \(0\|<+...x...+>\|ptr\);
* return ...;
Signed-off-by: Julia Lawall
Acked-by: Nishanth Aravamudan
Signed-off-by: Benjamin Herrenschmidt
 arch/powerpc/platforms/pseries/iommu.c | 7 +++++--
 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/arch/powerpc/platforms/pseries/iommu.c b/arch/powerpc/platforms/pseries/iommu.c
index 9f121a3..5905a3b 100644
--- a/arch/powerpc/platforms/pseries/iommu.c
+++ b/arch/powerpc/platforms/pseries/iommu.c
@@ -939,14 +939,14 @@ static u64 enable_ddw(struct pci_dev *dev, struct device_node *pdn)
 	if (ret) {
 		dev_info(&dev->dev, "failed to map direct window for %s: %d\n",
 			 dn->full_name, ret);
-		goto out_clear_window;
+		goto out_free_window;
 	ret = prom_add_property(pdn, win64);
 	if (ret) {
 		dev_err(&dev->dev, "unable to add dma window property for %s: %d",
 			 pdn->full_name, ret);
 	window->device = pdn;
@@ -958,6 +958,9 @@ static u64 enable_ddw(struct pci_dev *dev, struct device_node *pdn)
 	dma_addr = of_read_number(&create.addr_hi, 2);
 	goto out_unlock;
+out_free_window:
+	kfree(window);
 out_clear_window:
 	remove_ddw(pdn);
