staging: android: Use devm_kcalloc instead of devm_kzalloc
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Replace devm_kzalloc with devm_kcalloc to ensure there are no integer
overflows from the multiplication of a number * sizeof.
The following Coccinelle semantic patch was used to make this change:
expression dev,E1,E2,E3;
- devm_kzalloc(dev,E1*sizeof(E2),E3)
+ devm_kcalloc(dev,E1,sizeof(E2),E3)
Signed-off-by: Amitoj Kaur Chawla
 drivers/staging/android/timed_gpio.c | 5 ++---
 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/drivers/staging/android/timed_gpio.c b/drivers/staging/android/timed_gpio.c
index bcd9924..914fd10 100644
--- a/drivers/staging/android/timed_gpio.c
+++ b/drivers/staging/android/timed_gpio.c
@@ -92,9 +92,8 @@ static int timed_gpio_probe(struct platform_device *pdev)
 	if (!pdata)
 		return -EBUSY;
-	gpio_data = devm_kzalloc(&pdev->dev,
-				 sizeof(*gpio_data) * pdata->num_gpios,
-				 GFP_KERNEL);
+	gpio_data = devm_kcalloc(&pdev->dev, pdata->num_gpios,
+				 sizeof(*gpio_data), GFP_KERNEL);
 	if (!gpio_data)
 		return -ENOMEM;
BtrLinux
Privacy Overview
