spi: simplify devm_request_mem_region/devm_ioremap
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Convert the composition of devm_request_mem_region and devm_ioremap to a
single call to devm_ioremap_resource.  The associated call to
platform_get_resource is also simplified and moved next to the new call to
This was done using a combination of the semantic patches
devm_ioremap_resource.cocci and devm_request_and_ioremap.cocci, found in
the scripts/coccinelle/api directory.
This patch also removes the label exit_busy, to use the error code returned
by the failing operation, rather than always -EBUSY.
Signed-off-by: Julia Lawall
Signed-off-by: Mark Brown
 drivers/spi/spi-altera.c  | 17 +++++------------
 drivers/spi/spi-oc-tiny.c | 22 +++++++++-------------
 2 files changed, 14 insertions(+), 25 deletions(-)
diff --git a/drivers/spi/spi-altera.c b/drivers/spi/spi-altera.c
index 453fa5a..dce4a7e 100644
--- a/drivers/spi/spi-altera.c
+++ b/drivers/spi/spi-altera.c
@@ -239,15 +239,11 @@ static int altera_spi_probe(struct platform_device *pdev)
 	/* find and map our resources */
 	res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
-	if (!res)
-		goto exit_busy;
-	if (!devm_request_mem_region(&pdev->dev, res->start, resource_size(res),
-				     pdev->name))
-		goto exit_busy;
-	hw->base = devm_ioremap_nocache(&pdev->dev, res->start,
-					resource_size(res));
-	if (!hw->base)
-		goto exit_busy;
+	hw->base = devm_ioremap_resource(&pdev->dev, res);
+	if (IS_ERR(hw->base)) {
+		err = PTR_ERR(hw->base);
+		goto exit;
 	/* program defaults into the registers */
 	hw->imr = 0;		/* disable spi interrupts */
 	writel(hw->imr, hw->base + ALTERA_SPI_CONTROL);
@@ -274,9 +270,6 @@ static int altera_spi_probe(struct platform_device *pdev)
 	dev_info(&pdev->dev, "base %p, irq %d\n", hw->base, hw->irq);
 	return 0;
-exit_busy:
-	err = -EBUSY;
 exit:
 	spi_master_put(master);
 	return err;
diff --git a/drivers/spi/spi-oc-tiny.c b/drivers/spi/spi-oc-tiny.c
index 58deb79..d36ba90 100644
--- a/drivers/spi/spi-oc-tiny.c
+++ b/drivers/spi/spi-oc-tiny.c
@@ -315,15 +315,11 @@ static int tiny_spi_probe(struct platform_device *pdev)
-	if (!res)
-		goto exit_busy;
-				     pdev->name))
-		goto exit_busy;
-	if (!hw->base)
-		goto exit_busy;
+		goto exit;
 	/* irq is optional */
 	hw->irq = platform_get_irq(pdev, 0);
 	if (hw->irq >= 0) {
@@ -337,8 +333,10 @@ static int tiny_spi_probe(struct platform_device *pdev)
 	if (platp) {
 		hw->gpio_cs_count = platp->gpio_cs_count;
 		hw->gpio_cs = platp->gpio_cs;
-		if (platp->gpio_cs_count && !platp->gpio_cs)
-			goto exit_busy;
+		if (platp->gpio_cs_count && !platp->gpio_cs) {
+			err = -EBUSY;
+			goto exit;
 		hw->freq = platp->freq;
 		hw->baudwidth = platp->baudwidth;
 	} else {
@@ -365,8 +363,6 @@ static int tiny_spi_probe(struct platform_device *pdev)
 exit_gpio:
 	while (i-- > 0)
 		gpio_free(hw->gpio_cs[i]);
-exit_busy:
-	err = -EBUSY;
 exit:
 	return err;
BtrLinux
Privacy Overview
