PCI: tegra: replace devm_request_and_ioremap by devm_ioremap_resource
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Use devm_ioremap_resource instead of devm_request_and_ioremap.
This was done using the semantic patch
scripts/coccinelle/api/devm_ioremap_resource.cocci
Error-handling code was manually removed from the associated calls to
platform_get_resource.
Adjust the comment at the third platform_get_resource_byname to make clear
why ioremap is not done at this point.
Signed-off-by: Julia Lawall
Acked-by: Thierry Reding
Tested-by: Thierry Reding
Acked-by: Bjorn Helgaas
Acked-by: Stephen Warren
Signed-off-by: Thierry Reding
Signed-off-by: Olof Johansson
drivers/pci/host/pci-tegra.c | 31 ++++++++++---------------------
1 file changed, 10 insertions(+), 21 deletions(-)
diff --git a/drivers/pci/host/pci-tegra.c b/drivers/pci/host/pci-tegra.c
index 7356741..2e9888a 100644
--- a/drivers/pci/host/pci-tegra.c
+++ b/drivers/pci/host/pci-tegra.c
@@ -1031,32 +1031,21 @@ static int tegra_pcie_get_resources(struct tegra_pcie *pcie)
return err;
- /* request and remap controller registers */
pads = platform_get_resource_byname(pdev, IORESOURCE_MEM, "pads");
- if (!pads) {
- err = -EADDRNOTAVAIL;
+ pcie->pads = devm_ioremap_resource(&pdev->dev, pads);
+ if (IS_ERR(pcie->pads)) {
+ err = PTR_ERR(pcie->pads);
goto poweroff;
afi = platform_get_resource_byname(pdev, IORESOURCE_MEM, "afi");
- if (!afi) {
- goto poweroff;
- pcie->pads = devm_request_and_ioremap(&pdev->dev, pads);
- if (!pcie->pads) {
- goto poweroff;
- pcie->afi = devm_request_and_ioremap(&pdev->dev, afi);
- if (!pcie->afi) {
+ pcie->afi = devm_ioremap_resource(&pdev->dev, afi);
+ if (IS_ERR(pcie->afi)) {
+ err = PTR_ERR(pcie->afi);
goto poweroff;
- /* request and remap configuration space */
+ /* request configuration space, but remap later, on demand */
res = platform_get_resource_byname(pdev, IORESOURCE_MEM, "cs");
if (!res) {
@@ -1492,9 +1481,9 @@ static int tegra_pcie_parse_dt(struct tegra_pcie *pcie)
rp->lanes = value;
rp->pcie = pcie;
- rp->base = devm_request_and_ioremap(pcie->dev, &rp->regs);
- if (!rp->base)
- return -EADDRNOTAVAIL;
+ rp->base = devm_ioremap_resource(pcie->dev, &rp->regs);
+ if (IS_ERR(rp->base))
+ return PTR_ERR(rp->base);
list_add_tail(&rp->list, &pcie->ports);
return err;
- if (!pads) {
goto poweroff;
- if (!afi) {
- goto poweroff;
- goto poweroff;
- if (!pcie->afi) {
goto poweroff;
if (!res) {
rp->lanes = value;
rp->pcie = pcie;
- if (!rp->base)
