spi: make Open Firmware device id constant
Author: Márton Németh <nm127@freemail.hu>
The match_table field of the struct of_device_id is constant
in  so it is worth to make the initialization
data constant.
The semantic match that finds this kind of pattern is as follows:
(http://coccinelle.lip6.fr/)
@r@
disable decl_init,const_decl_init;
identifier I1, I2, x;
	struct I1 {
	  const struct I2 *x;
@s@
identifier r.I1, y;
identifier r.x, E;
	struct I1 y = {
	  .x = E,
@c@
identifier r.I2;
identifier s.E;
	const struct I2 E[] = ... ;
@depends on !c@
identifier r.I2;
identifier s.E;
+	const
	struct I2 E[] = ...;
Signed-off-by: Márton Németh
Cc: Julia Lawall
Cc: cocci@diku.dk
Signed-off-by: Grant Likely
 drivers/spi/mpc52xx_psc_spi.c | 2 +-
 drivers/spi/mpc52xx_spi.c     | 2 +-
 drivers/spi/spi_ppc4xx.c      | 2 +-
 drivers/spi/xilinx_spi_of.c   | 2 +-
 4 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/spi/mpc52xx_psc_spi.c b/drivers/spi/mpc52xx_psc_spi.c
index f50c81d..0474786 100644
--- a/drivers/spi/mpc52xx_psc_spi.c
+++ b/drivers/spi/mpc52xx_psc_spi.c
@@ -503,7 +503,7 @@ static int __exit mpc52xx_psc_spi_of_remove(struct of_device *op)
 	return mpc52xx_psc_spi_do_remove(&op->dev);
-static struct of_device_id mpc52xx_psc_spi_of_match[] = {
+static const struct of_device_id mpc52xx_psc_spi_of_match[] = {
 	{ .compatible = "fsl,mpc5200-psc-spi", },
 	{ .compatible = "mpc5200-psc-spi", }, /* old */
diff --git a/drivers/spi/mpc52xx_spi.c b/drivers/spi/mpc52xx_spi.c
index 45bfe64..6eab465 100644
--- a/drivers/spi/mpc52xx_spi.c
+++ b/drivers/spi/mpc52xx_spi.c
@@ -550,7 +550,7 @@ static int __devexit mpc52xx_spi_remove(struct of_device *op)
 	return 0;
-static struct of_device_id mpc52xx_spi_match[] __devinitdata = {
+static const struct of_device_id mpc52xx_spi_match[] __devinitconst = {
 	{ .compatible = "fsl,mpc5200-spi", },
diff --git a/drivers/spi/spi_ppc4xx.c b/drivers/spi/spi_ppc4xx.c
index 140a18d..6d8d402 100644
--- a/drivers/spi/spi_ppc4xx.c
+++ b/drivers/spi/spi_ppc4xx.c
@@ -578,7 +578,7 @@ static int __exit spi_ppc4xx_of_remove(struct of_device *op)
 	return 0;
-static struct of_device_id spi_ppc4xx_of_match[] = {
+static const struct of_device_id spi_ppc4xx_of_match[] = {
 	{ .compatible = "ibm,ppc4xx-spi", },
diff --git a/drivers/spi/xilinx_spi_of.c b/drivers/spi/xilinx_spi_of.c
index 71dc3ad..ed34a8d 100644
--- a/drivers/spi/xilinx_spi_of.c
+++ b/drivers/spi/xilinx_spi_of.c
@@ -99,7 +99,7 @@ static int __exit xilinx_spi_of_remove(struct of_device *op)
 	return xilinx_spi_remove(op);
-static struct of_device_id xilinx_spi_of_match[] = {
+static const struct of_device_id xilinx_spi_of_match[] = {
 	{ .compatible = "xlnx,xps-spi-2.00.a", },
 	{ .compatible = "xlnx,xps-spi-2.00.b", },
BtrLinux
Privacy Overview
