serial: st-asc: replace devm_request_and_ioremap by devm_ioremap_resource
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Use devm_ioremap_resource instead of devm_request_and_ioremap.
This was done using the semantic patch
scripts/coccinelle/api/devm_ioremap_resource.cocci
and various manual modifications to move associated calls to
platform_get_resource closer to the resulting call to devm_ioremap_resource
and to remove the associated error handling code.
The initialization of port->mapbase is also moved lower, to take advantage
of the NULL test on res performed by devm_ioremap_resource.
Signed-off-by: Julia Lawall
 drivers/tty/serial/st-asc.c | 18 ++++++------------
 1 file changed, 6 insertions(+), 12 deletions(-)
diff --git a/drivers/tty/serial/st-asc.c b/drivers/tty/serial/st-asc.c
index 2ff4b1b..4f5caa38 100644
--- a/drivers/tty/serial/st-asc.c
+++ b/drivers/tty/serial/st-asc.c
@@ -665,26 +665,20 @@ static int asc_init_port(struct asc_port *ascport,
 			  struct platform_device *pdev)
 	struct uart_port *port = &ascport->port;
-	struct resource *res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
-	if (!res) {
-		dev_err(&pdev->dev, "Unable to get io resource\n");
-		return -ENODEV;
+	struct resource *res;
 	port->iotype	= UPIO_MEM;
 	port->flags	= UPF_BOOT_AUTOCONF;
 	port->ops	= &asc_uart_ops;
 	port->fifosize	= ASC_FIFO_SIZE;
 	port->dev	= &pdev->dev;
-	port->mapbase	= res->start;
 	port->irq	= platform_get_irq(pdev, 0);
-	port->membase = devm_request_and_ioremap(&pdev->dev, res);
-	if (!port->membase) {
-		dev_err(&pdev->dev, "Unable to request io memory\n");
-		return -ENODEV;
+	res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
+	port->membase = devm_ioremap_resource(&pdev->dev, res);
+	if (IS_ERR(port->membase))
+		return PTR_ERR(port->membase);
+	port->mapbase = res->start;
 	spin_lock_init(&port->lock);
BtrLinux
Privacy Overview
