MIPS: ath79: simplify platform_get_resource_byname/devm_ioremap_resource
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Remove unneeded error handling on the result of a call to
platform_get_resource_byname when the value is passed to devm_ioremap_resource.
A simplified version of the semantic patch that makes this change is as
follows: (http://coccinelle.lip6.fr/)
expression pdev,res,e,e1;
expression ret != 0;
identifier l;
res = platform_get_resource_byname(...);
- if (res == NULL) { ... \(goto l;\|return ret;\) }
e = devm_ioremap_resource(e1, res);
Signed-off-by: Julia Lawall
Acked-by: Gabor Juhos
Cc: kernel-janitors@vger.kernel.org
Cc: linux-mips@linux-mips.org
Cc: linux-kernel@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/5725/
Signed-off-by: Ralf Baechle
arch/mips/pci/pci-ar71xx.c | 3 ---
arch/mips/pci/pci-ar724x.c | 9 ---------
2 files changed, 12 deletions(-)
diff --git a/arch/mips/pci/pci-ar71xx.c b/arch/mips/pci/pci-ar71xx.c
index 18517dd..d471a26 100644
--- a/arch/mips/pci/pci-ar71xx.c
+++ b/arch/mips/pci/pci-ar71xx.c
@@ -363,9 +363,6 @@ static int ar71xx_pci_probe(struct platform_device *pdev)
spin_lock_init(&apc->lock);
res = platform_get_resource_byname(pdev, IORESOURCE_MEM, "cfg_base");
- if (!res)
- return -EINVAL;
apc->cfg_base = devm_ioremap_resource(&pdev->dev, res);
if (IS_ERR(apc->cfg_base))
return PTR_ERR(apc->cfg_base);
diff --git a/arch/mips/pci/pci-ar724x.c b/arch/mips/pci/pci-ar724x.c
index 65ec032..785b265 100644
--- a/arch/mips/pci/pci-ar724x.c
+++ b/arch/mips/pci/pci-ar724x.c
@@ -362,25 +362,16 @@ static int ar724x_pci_probe(struct platform_device *pdev)
return -ENOMEM;
res = platform_get_resource_byname(pdev, IORESOURCE_MEM, "ctrl_base");
- if (!res)
- return -EINVAL;
apc->ctrl_base = devm_ioremap_resource(&pdev->dev, res);
if (IS_ERR(apc->ctrl_base))
return PTR_ERR(apc->ctrl_base);
- if (!res)
- return -EINVAL;
apc->devcfg_base = devm_ioremap_resource(&pdev->dev, res);
if (IS_ERR(apc->devcfg_base))
return PTR_ERR(apc->devcfg_base);
res = platform_get_resource_byname(pdev, IORESOURCE_MEM, "crp_base");
- if (!res)
- return -EINVAL;
apc->crp_base = devm_ioremap_resource(&pdev->dev, res);
if (IS_ERR(apc->crp_base))
return PTR_ERR(apc->crp_base); |
- if (!res)
- return -EINVAL;
return -ENOMEM;
- if (!res)
- return -EINVAL;
- if (!res)
- return -EINVAL;
- if (!res)
- return -EINVAL;
