[SCSI] drivers/message/fusion: Adjust confusing if indentation
Indent the branch of an if.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@r disable braces4@
position p1,p2;
statement S1,S2;
if (...) { ... }
if (...) S1@p1 S2@p2
@script:python@
p1 << r.p1;
p2 << r.p2;
if (p1[0].column == p2[0].column):
  cocci.print_main("branch",p1)
  cocci.print_secs("after",p2)
Signed-off-by: Julia Lawall
Acked-by: "Desai, Kashyap"
Signed-off-by: James Bottomley
 drivers/message/fusion/mptbase.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/message/fusion/mptbase.c b/drivers/message/fusion/mptbase.c
index b88a244..667d132 100644
--- a/drivers/message/fusion/mptbase.c
+++ b/drivers/message/fusion/mptbase.c
@@ -8050,7 +8050,7 @@ union loginfo_type {
 			code_desc = ir_code_str[sas_loginfo.dw.code];
 			if (sas_loginfo.dw.subcode >=
 			    ARRAY_SIZE(raid_sub_code_str))
-			break;
+				break;
 			if (sas_loginfo.dw.code == 0)
 				sub_code_desc =
 				    raid_sub_code_str[sas_loginfo.dw.subcode];
BtrLinux
Privacy Overview
