drivers/net/wireless/ath/ath9k: Adjust confusing if indentation
Outdent the code following the if.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@r disable braces4@
position p1,p2;
statement S1,S2;
if (...) { ... }
if (...) S1@p1 S2@p2
@script:python@
p1 << r.p1;
p2 << r.p2;
if (p1[0].column == p2[0].column):
cocci.print_main("branch",p1)
cocci.print_secs("after",p2)
Signed-off-by: Julia Lawall
Acked-by: Luis R. Rodriguez
Signed-off-by: John W. Linville
drivers/net/wireless/ath/ath9k/ar9003_mac.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/wireless/ath/ath9k/ar9003_mac.c b/drivers/net/wireless/ath/ath9k/ar9003_mac.c
index 5b995be..a462da2 100644
--- a/drivers/net/wireless/ath/ath9k/ar9003_mac.c
+++ b/drivers/net/wireless/ath/ath9k/ar9003_mac.c
@@ -185,7 +185,7 @@ static bool ar9003_hw_get_isr(struct ath_hw *ah, enum ath9k_int *masked)
ath_print(common, ATH_DBG_INTERRUPT,
"AR_INTR_SYNC_LOCAL_TIMEOUT\n");
- REG_WRITE(ah, AR_INTR_SYNC_CAUSE_CLR, sync_cause);
+ REG_WRITE(ah, AR_INTR_SYNC_CAUSE_CLR, sync_cause);
(void) REG_READ(ah, AR_INTR_SYNC_CAUSE_CLR);
