[S390] drivers: Correct size given to memset
Memset should be given the size of the structure, not the size of the pointer.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
type T;
T *x;
expression E;
memset(x, E, sizeof(
x))
Signed-off-by: Julia Lawall
Signed-off-by: Heiko Carstens
Signed-off-by: Martin Schwidefsky
drivers/s390/cio/fcx.c | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/s390/cio/fcx.c b/drivers/s390/cio/fcx.c
index 61677df..ca5e9bb 100644
--- a/drivers/s390/cio/fcx.c
+++ b/drivers/s390/cio/fcx.c
@@ -163,7 +163,7 @@ void tcw_finalize(struct tcw *tcw, int num_tidaws)
/* Add tcat to tccb. */
tccb = tcw_get_tccb(tcw);
tcat = (struct tccb_tcat *) &tccb->tca[tca_size(tccb)];
- memset(tcat, 0, sizeof(tcat));
+ memset(tcat, 0, sizeof(*tcat));
/* Calculate tcw input/output count and tcat transport count. */
count = calc_dcw_count(tccb);
if (tcw->w && (tcw->flags & TCW_FLAGS_OUTPUT_TIDA))
@@ -269,7 +269,7 @@ EXPORT_SYMBOL(tccb_init);
void tsb_init(struct tsb *tsb)
- memset(tsb, 0, sizeof(tsb));
+ memset(tsb, 0, sizeof(*tsb));
EXPORT_SYMBOL(tsb_init); |
