drivers/video/via/viafbdev.c: correct code taking the size of a pointer
sizeof(viafb_gamma_table) is just the size of the pointer.  This is changed
to the size used when calling kmalloc to initialize the pointer.
A simplified version of the semantic patch that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
expression *x;
expression f;
type T;
*f(...,(T)x,...)
Signed-off-by: Julia Lawall
Acked-by: Florian Tobias Schandinat
Cc: Joseph Chan
Cc: Scott Fang
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 drivers/video/via/viafbdev.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/video/via/viafbdev.c b/drivers/video/via/viafbdev.c
index 10d8c4b..d8df17a 100644
--- a/drivers/video/via/viafbdev.c
+++ b/drivers/video/via/viafbdev.c
@@ -680,7 +680,7 @@ static int viafb_ioctl(struct fb_info *info, u_int cmd, u_long arg)
 		if (!viafb_gamma_table)
 			return -ENOMEM;
 		if (copy_from_user(viafb_gamma_table, argp,
-				sizeof(viafb_gamma_table))) {
+				256 * sizeof(u32))) {
 			kfree(viafb_gamma_table);
 			return -EFAULT;
@@ -694,7 +694,7 @@ static int viafb_ioctl(struct fb_info *info, u_int cmd, u_long arg)
 			return -ENOMEM;
 		viafb_get_gamma_table(viafb_gamma_table);
 		if (copy_to_user(argp, viafb_gamma_table,
 			return -EFAULT;
