rndis_wlan: fix checking for default value
Author: Andrzej Hajda <a.hajda@samsung.com>
Thresholds uses -1 to indicate that default value should be used.
Since thresholds are unsigned sign checking makes no sense.
The problem has been detected using proposed semantic patch
scripts/coccinelle/tests/unsigned_lesser_than_zero.cocci [1].
[1]: http://permalink.gmane.org/gmane.linux.kernel/2038576
Signed-off-by: Andrzej Hajda
Signed-off-by: David S. Miller
 drivers/net/wireless/rndis_wlan.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/wireless/rndis_wlan.c b/drivers/net/wireless/rndis_wlan.c
index 71a825c..a13d1f2 100644
--- a/drivers/net/wireless/rndis_wlan.c
+++ b/drivers/net/wireless/rndis_wlan.c
@@ -1236,7 +1236,7 @@ static int set_rts_threshold(struct usbnet *usbdev, u32 rts_threshold)
 	netdev_dbg(usbdev->net, "%s(): %i\n", __func__, rts_threshold);
-	if (rts_threshold < 0 || rts_threshold > 2347)
+	if (rts_threshold == -1 || rts_threshold > 2347)
 		rts_threshold = 2347;
 	tmp = cpu_to_le32(rts_threshold);
