orinoco: fix checking for default value
Author: Andrzej Hajda <a.hajda@samsung.com>
Thresholds uses -1 to indicate that default value should be used.
Since thresholds are unsigned sign checking makes no sense.
The problem has been detected using proposed semantic patch
scripts/coccinelle/tests/unsigned_lesser_than_zero.cocci [1].
[1]: http://permalink.gmane.org/gmane.linux.kernel/2038576
Signed-off-by: Andrzej Hajda
Signed-off-by: David S. Miller
 drivers/net/wireless/orinoco/cfg.c | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/net/wireless/orinoco/cfg.c b/drivers/net/wireless/orinoco/cfg.c
index a9e94b6..0f6ea31 100644
--- a/drivers/net/wireless/orinoco/cfg.c
+++ b/drivers/net/wireless/orinoco/cfg.c
@@ -220,7 +220,7 @@ static int orinoco_set_wiphy_params(struct wiphy *wiphy, u32 changed)
 	if (changed & WIPHY_PARAM_FRAG_THRESHOLD) {
 		/* Set fragmentation */
 		if (priv->has_mwo) {
-			if (wiphy->frag_threshold < 0)
+			if (wiphy->frag_threshold == -1)
 				frag_value = 0;
 			else {
 				printk(KERN_WARNING "%s: Fixed fragmentation "
@@ -230,7 +230,7 @@ static int orinoco_set_wiphy_params(struct wiphy *wiphy, u32 changed)
 				frag_value = 1;
 		} else {
 				frag_value = 2346;
 			else if ((wiphy->frag_threshold < 257) ||
 				 (wiphy->frag_threshold > 2347))
@@ -252,7 +252,7 @@ static int orinoco_set_wiphy_params(struct wiphy *wiphy, u32 changed)
 		 * the upper limit.
-		if (wiphy->rts_threshold < 0)
+		if (wiphy->rts_threshold == -1)
 			rts_value = 2347;
 		else if (wiphy->rts_threshold > 2347)
 			err = -EINVAL;
