RDMA/iwcm: Test rdma_create_id() for IS_ERR rather than 0
The function rdma_create_id() always returns either a valid pointer or
a value made with ERR_PTR, so its result should be tested with IS_ERR,
not with a test for 0.
The problem was found using the following semantic match.
(http://www.emn.fr/x-info/coccinelle/)
@a@
expression E, E1;
statement S,S1;
position p;
E = rdma_create_id(...)
... when != E = E1
if@p (E) S else S1
@n@
position a.p;
expression E,E1;
statement S,S1;
E = NULL
... when != E = E1
if@p (E) S else S1
@depends on !n@
expression E;
statement S,S1;
position a.p;
* if@p (E)
  S else S1
Signed-off-by: Julia Lawall
Signed-off-by: Roland Dreier
 drivers/infiniband/core/cma.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/infiniband/core/cma.c b/drivers/infiniband/core/cma.c
index d81c156..671f137 100644
--- a/drivers/infiniband/core/cma.c
+++ b/drivers/infiniband/core/cma.c
@@ -1289,7 +1289,7 @@ static int iw_conn_req_handler(struct iw_cm_id *cm_id,
 	new_cm_id = rdma_create_id(listen_id->id.event_handler,
 				   listen_id->id.context,
 				   RDMA_PS_TCP);
-	if (!new_cm_id) {
+	if (IS_ERR(new_cm_id)) {
 		ret = -ENOMEM;
 		goto out;
BtrLinux
Privacy Overview
