drivers/media/video/c-qcam.c | 7 +++++--
drivers/media/video/ivtv/ivtv-fileops.c | 4 +++-
drivers/media/video/ivtv/ivtv-mailbox.c | 11 +++++++----
drivers/media/video/ivtv/ivtv-streams.c | 3 ++-
4 files changed, 17 insertions(+), 8 deletions(-)
diff --git a/drivers/media/video/c-qcam.c b/drivers/media/video/c-qcam.c
index 2c85ced..fe1e67b 100644
--- a/drivers/media/video/c-qcam.c
+++ b/drivers/media/video/c-qcam.c
@@ -36,6 +36,7 @@
#include <linux/videodev.h>
#include <media/v4l2-common.h>
#include <linux/mutex.h>
+#include <linux/jiffies.h>
#include <asm/uaccess.h>
@@ -95,7 +96,8 @@ static unsigned int qcam_await_ready1(struct qcam_device *qcam,
unsigned long oldjiffies = jiffies;
unsigned int i;
- for (oldjiffies = jiffies; (jiffies - oldjiffies) < msecs_to_jiffies(40); )
+ for (oldjiffies = jiffies;
+ time_before(jiffies, oldjiffies + msecs_to_jiffies(40)); )
if (qcam_ready1(qcam) == value)
return 0;
@@ -120,7 +122,8 @@ static unsigned int qcam_await_ready2(struct qcam_device *qcam, int value)
unsigned int i;
if (qcam_ready2(qcam) == value)
return 0;
diff --git a/drivers/media/video/ivtv/ivtv-fileops.c b/drivers/media/video/ivtv/ivtv-fileops.c
index d949a81..a7640c4 100644
--- a/drivers/media/video/ivtv/ivtv-fileops.c
+++ b/drivers/media/video/ivtv/ivtv-fileops.c
@@ -219,7 +219,9 @@ static struct ivtv_buffer *ivtv_get_buffer(struct ivtv_stream *s, int non_block,
/* Process pending program info updates and pending VBI data */
ivtv_update_pgm_info(itv);
- if (jiffies - itv->dualwatch_jiffies > msecs_to_jiffies(1000)) {
+ if (time_after(jiffies,
+ itv->dualwatch_jiffies +
+ msecs_to_jiffies(1000))) {
itv->dualwatch_jiffies = jiffies;
ivtv_dualwatch(itv);
diff --git a/drivers/media/video/ivtv/ivtv-mailbox.c b/drivers/media/video/ivtv/ivtv-mailbox.c
index 13a6c37..1b5c0ac 100644
--- a/drivers/media/video/ivtv/ivtv-mailbox.c
+++ b/drivers/media/video/ivtv/ivtv-mailbox.c
@@ -177,7 +177,8 @@ static int get_mailbox(struct ivtv *itv, struct ivtv_mailbox_data *mbdata, int f
/* Sleep before a retry, if not atomic */
if (!(flags & API_NO_WAIT_MB)) {
- if (jiffies - then > msecs_to_jiffies(10*retries))
+ then + msecs_to_jiffies(10*retries)))
break;
ivtv_msleep_timeout(10, 0);
@@ -244,7 +245,9 @@ static int ivtv_api_call(struct ivtv *itv, int cmd, int args, u32 data[])
data, then just return 0 as there is no need to issue this command again.
Just an optimization to prevent unnecessary use of mailboxes. */
if (itv->api_cache[cmd].last_jiffies &&
- jiffies - itv->api_cache[cmd].last_jiffies < msecs_to_jiffies(1800000) &&
+ itv->api_cache[cmd].last_jiffies +
+ msecs_to_jiffies(1800000)) &&
!memcmp(data, itv->api_cache[cmd].data, sizeof(itv->api_cache[cmd].data))) {
itv->api_cache[cmd].last_jiffies = jiffies;
return 0;
@@ -299,7 +302,7 @@ static int ivtv_api_call(struct ivtv *itv, int cmd, int args, u32 data[])
while (!(readl(&mbox->flags) & IVTV_MBOX_FIRMWARE_DONE)) {
- if (jiffies - then > api_timeout) {
+ if (time_after(jiffies, then + api_timeout)) {
IVTV_DEBUG_WARN("Could not get result (%s)\n", api_info[cmd].name);
/* reset the mailbox, but it is likely too late already */
write_sync(0, &mbox->flags);
@@ -311,7 +314,7 @@ static int ivtv_api_call(struct ivtv *itv, int cmd, int args, u32 data[])
else
ivtv_msleep_timeout(1, 0);
- if (jiffies - then > msecs_to_jiffies(100))
+ if (time_after(jiffies, then + msecs_to_jiffies(100)))
IVTV_DEBUG_WARN("%s took %u jiffies\n",
api_info[cmd].name,
jiffies_to_msecs(jiffies - then));
diff --git a/drivers/media/video/ivtv/ivtv-streams.c b/drivers/media/video/ivtv/ivtv-streams.c
index 24d98ec..4ab8d36 100644
--- a/drivers/media/video/ivtv/ivtv-streams.c
+++ b/drivers/media/video/ivtv/ivtv-streams.c
@@ -768,7 +768,8 @@ int ivtv_stop_v4l2_encode_stream(struct ivtv_stream *s, int gop_end)
/* wait 2s for EOS interrupt */
while (!test_bit(IVTV_F_I_EOS, &itv->i_flags) &&
- jiffies < then + msecs_to_jiffies (2000)) {
+ then + msecs_to_jiffies(2000))) {
schedule_timeout(msecs_to_jiffies(10));
