qeth: fix possible memory leak in qeth_l3_add_[vipa|rxip]()
Author: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
ipaddr has been allocated in function qeth_l3_add_vipa() but
does not free before leaving from the error handling cases. The
same problem also exists in function qeth_l3_add_rxip().
spatch with a semantic match is used to found this problem.
(http://coccinelle.lip6.fr/)
Signed-off-by: Wei Yongjun
Signed-off-by: Frank Blaschka
Signed-off-by: David S. Miller
 drivers/s390/net/qeth_l3_main.c | 2 ++
 1 file changed, 2 insertions(+)
diff --git a/drivers/s390/net/qeth_l3_main.c b/drivers/s390/net/qeth_l3_main.c
index c5f03fa..4cd310c 100644
--- a/drivers/s390/net/qeth_l3_main.c
+++ b/drivers/s390/net/qeth_l3_main.c
@@ -794,6 +794,7 @@ int qeth_l3_add_vipa(struct qeth_card *card, enum qeth_prot_versions proto,
 		rc = -EEXIST;
 	spin_unlock_irqrestore(&card->ip_lock, flags);
 	if (rc) {
+		kfree(ipaddr);
 		return rc;
 	if (!qeth_l3_add_ip(card, ipaddr))
@@ -858,6 +859,7 @@ int qeth_l3_add_rxip(struct qeth_card *card, enum qeth_prot_versions proto,
 		rc = -EEXIST;
 	if (rc) {
+		kfree(ipaddr);
 		return rc;
BtrLinux
Privacy Overview
