edac_mc: fix messy kfree calls in the error path
Author: Fengguang Wu <fengguang.wu@intel.com>
coccinelle warns about:
+ drivers/edac/edac_mc.c:429:9-23: ERROR: reference preceded by free on line 429
421 if (mci->csrows) {
> 422 for (chn = 0; chn < tot_channels; chn++) {
423 csr = mci->csrows[chn];
424 if (csr) {
> 425 for (chn = 0; chn < tot_channels; chn++)
426 kfree(csr->channels[chn]);
427 kfree(csr);
428 }
> 429 kfree(mci->csrows[i]);
430 }
431 kfree(mci->csrows);
432 }
and that code block seem to mess things up in several ways (double free, memory
leak, out-of-bound reads etc.):
L422: The iterator "chn" and bound "tot_channels" are totally wrong. Should be
"row" and "tot_csrows" respectively. Which means either memory leak, or
out-of-bound reads (which if does not trigger an immediate page fault
error, will further lead to kfree() on random addresses).
L425: The inner loop is reusing the same iterator "chn" as the outer loop,
which could lead to premature end of the outer loop, and hence memory leak.
L429: The array index 'i' in mci->csrows[i] is a temporary value used in
previous loops, and won't change at all in the current loop. Which
means either out-of-bound read and possibly kfree(random number), or the
same mci->csrows[i] get freed once and again, and possibly double free
for the kfree(csr) in L427.
L426/L427: a kfree(csr->channels) is needed in between to avoid leaking the memory.
The buggy code was introduced by commit de3910eb ("edac: change the mem
allocation scheme to make Documentation/kobject.txt happy") in the 3.6-rc1
merge window. Fix it by freeing up resources in this order:
free csrows[i]->channels[j]
free csrows[i]
free csrows
CC: Mauro Carvalho Chehab
CC: Shaun Ruffell
Signed-off-by: Fengguang Wu
Signed-off-by: Linus Torvalds
drivers/edac/edac_mc.c | 12 +++++++-----
1 file changed, 7 insertions(+), 5 deletions(-)
diff --git a/drivers/edac/edac_mc.c b/drivers/edac/edac_mc.c
index 616d90b..9037ffa 100644
--- a/drivers/edac/edac_mc.c
+++ b/drivers/edac/edac_mc.c
@@ -419,14 +419,16 @@ error:
kfree(mci->dimms);
if (mci->csrows) {
- for (chn = 0; chn < tot_channels; chn++) {
- csr = mci->csrows[chn];
+ for (row = 0; row < tot_csrows; row++) {
+ csr = mci->csrows[row];
if (csr) {
- kfree(csr->channels[chn]);
+ if (csr->channels) {
+ for (chn = 0; chn < tot_channels; chn++)
+ kfree(csr->channels[chn]);
+ kfree(csr->channels);
kfree(csr);
- kfree(mci->csrows[i]);
kfree(mci->csrows);
kfree(mci->dimms);
if (mci->csrows) {
if (csr) {
kfree(csr);
kfree(mci->csrows);
