powerpc/powernv: add missing of_node_put
Author: Julia Lawall <Julia.Lawall@lip6.fr>
for_each_child_of_node performs an of_node_get on each iteration, so
a break out of the loop requires an of_node_put.
A simplified version of the semantic patch that fixes this problem is as
follows (http://coccinelle.lip6.fr):
expression root,e;
local idexpression child;
 for_each_child_of_node(root, child) {
   ... when != of_node_put(child)
       when != e = child
   return child;
+  of_node_put(child);
?  return ...;
Signed-off-by: Julia Lawall
Signed-off-by: Jacek Anaszewski
 drivers/leds/leds-powernv.c | 8 ++++++--
 1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/drivers/leds/leds-powernv.c b/drivers/leds/leds-powernv.c
index 2c5c5b1..1e75e1f 100644
--- a/drivers/leds/leds-powernv.c
+++ b/drivers/leds/leds-powernv.c
@@ -262,15 +262,19 @@ static int powernv_led_classdev(struct platform_device *pdev,
 		while ((cur = of_prop_next_string(p, cur)) != NULL) {
 			powernv_led = devm_kzalloc(dev, sizeof(*powernv_led),
 						   GFP_KERNEL);
-			if (!powernv_led)
+			if (!powernv_led) {
+				of_node_put(np);
 				return -ENOMEM;
 			powernv_led->common = powernv_led_common;
 			powernv_led->loc_code = (char *)np->name;
 			rc = powernv_led_create(dev, powernv_led, cur);
-			if (rc)
+			if (rc) {
+				of_node_put(np);
 				return rc;
 		} /* while end */
BtrLinux
Privacy Overview
