leds: bcm6358: add missing of_node_put
Author: Julia Lawall <Julia.Lawall@lip6.fr>
for_each_available_child_of_node performs an of_node_get on each
iteration, so a break out of the loop requires an of_node_put.
A simplified version of the semantic patch that fixes this problem is as
follows (http://coccinelle.lip6.fr):
expression root,e;
local idexpression child;
for_each_available_child_of_node(root, child) {
... when != of_node_put(child)
when != e = child
return child;
+ of_node_put(child);
? return ...;
Signed-off-by: Julia Lawall
Signed-off-by: Jacek Anaszewski
drivers/leds/leds-bcm6358.c | 4 +++-
1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/leds/leds-bcm6358.c b/drivers/leds/leds-bcm6358.c
index 7ea3526..82b4ee1 100644
--- a/drivers/leds/leds-bcm6358.c
+++ b/drivers/leds/leds-bcm6358.c
@@ -215,8 +215,10 @@ static int bcm6358_leds_probe(struct platform_device *pdev)
rc = bcm6358_led(dev, child, reg, mem, lock);
- if (rc < 0)
+ if (rc < 0) {
return rc;
return 0; |
- if (rc < 0)
+ if (rc < 0) {
return rc;
return 0;
