powerpc/mpc5xxx: delete unneeded test before of_node_put
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Of_node_put supports NULL as its argument, so the initial test is not
necessary.
Suggested by Uwe Kleine-König.
The semantic patch that fixes this problem is as follows:
(http://coccinelle.lip6.fr/)
expression e;
-if (e)
of_node_put(e);
Signed-off-by: Julia Lawall
Signed-off-by: Michael Ellerman
arch/powerpc/sysdev/mpc5xxx_clocks.c | 3 +--
1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/arch/powerpc/sysdev/mpc5xxx_clocks.c b/arch/powerpc/sysdev/mpc5xxx_clocks.c
index 5492dc5..f4f0301 100644
--- a/arch/powerpc/sysdev/mpc5xxx_clocks.c
+++ b/arch/powerpc/sysdev/mpc5xxx_clocks.c
@@ -26,8 +26,7 @@ unsigned long mpc5xxx_get_bus_frequency(struct device_node *node)
of_node_put(node);
node = np;
- if (node)
- of_node_put(node);
+ of_node_put(node);
return p_bus_freq ? *p_bus_freq : 0;
of_node_put(node);
node = np;
- if (node)
