powerpc/pseries: delete unneeded test before of_node_put
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Of_node_put supports NULL as its argument, so the initial test is not
necessary.
Suggested by Uwe Kleine-König.
The semantic patch that fixes this problem is as follows:
(http://coccinelle.lip6.fr/)
expression e;
-if (e)
of_node_put(e);
Signed-off-by: Julia Lawall
Acked-by: Benjamin Herrenschmidt
Signed-off-by: Michael Ellerman
arch/powerpc/platforms/pseries/iommu.c | 3 +--
1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/arch/powerpc/platforms/pseries/iommu.c b/arch/powerpc/platforms/pseries/iommu.c
index 49bcf7c..1cc3db9 100644
--- a/arch/powerpc/platforms/pseries/iommu.c
+++ b/arch/powerpc/platforms/pseries/iommu.c
@@ -574,8 +574,7 @@ static void pci_dma_bus_setup_pSeries(struct pci_bus *bus)
while (isa_dn && isa_dn != dn)
isa_dn = isa_dn->parent;
- if (isa_dn_orig)
- of_node_put(isa_dn_orig);
+ of_node_put(isa_dn_orig);
/* Count number of direct PCI children of the PHB. */
for (children = 0, tmp = dn->child; tmp; tmp = tmp->sibling) |
- if (isa_dn_orig)
