[POWERPC] Use FIELD_SIZEOF in drivers/block/viodasd.c
Robert P.J. Day proposed to use the macro FIELD_SIZEOF in replace of code
that matches its definition.
The modification was made using the following semantic patch
(http://www.emn.fr/x-info/coccinelle/)
@haskernel@
#include
@depends on haskernel@
type t;
identifier f;
- (sizeof(((t*)0)->f))
+ FIELD_SIZEOF(t, f)
type t;
identifier f;
- sizeof(((t*)0)->f)
Signed-off-by: Julia Lawall
Cc: Jens Axboe
Cc: Benjamin Herrenschmidt
Acked-by: Stephen Rothwell
Signed-off-by: Andrew Morton
Signed-off-by: Paul Mackerras
 drivers/block/viodasd.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/block/viodasd.c b/drivers/block/viodasd.c
index 41ca721..ebfe038 100644
--- a/drivers/block/viodasd.c
+++ b/drivers/block/viodasd.c
@@ -69,7 +69,7 @@ MODULE_LICENSE("GPL");
 enum {
 	PARTITION_SHIFT = 3,
 	MAX_DISKNO = HVMAXARCHITECTEDVIRTUALDISKS,
-	MAX_DISK_NAME = sizeof(((struct gendisk *)0)->disk_name)
+	MAX_DISK_NAME = FIELD_SIZEOF(struct gendisk, disk_name)
 static DEFINE_SPINLOCK(viodasd_spinlock);
BtrLinux
Privacy Overview
