[POWERPC] Use FIELD_SIZEOF in arch/ppc
Robert P.J. Day proposed to use the macro FIELD_SIZEOF in replace of code
that matches its definition.
The modification was made using the following semantic patch
(http://www.emn.fr/x-info/coccinelle/)
@haskernel@
#include
@depends on haskernel@
type t;
identifier f;
- (sizeof(((t*)0)->f))
+ FIELD_SIZEOF(t, f)
type t;
identifier f;
- sizeof(((t*)0)->f)
Signed-off-by: Julia Lawall
Signed-off-by: Paul Mackerras
 arch/ppc/8xx_io/commproc.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/ppc/8xx_io/commproc.c b/arch/ppc/8xx_io/commproc.c
index 9d656de..752443d 100644
--- a/arch/ppc/8xx_io/commproc.c
+++ b/arch/ppc/8xx_io/commproc.c
@@ -43,7 +43,7 @@
 	u32 offset = offsetof(immap_t, member);				\
 	void *addr = ioremap (IMAP_ADDR + offset,			\
-			      sizeof( ((immap_t*)0)->member));		\
+			      FIELD_SIZEOF(immap_t, member));		\
 	addr;								\
BtrLinux
Privacy Overview
