drivers/video: add missing pci_dev_get
pci_get_device does a pci_dev_get, so pci_dev_put needs to be called in an
error case
The problem was fixed using the following semantic patch.
(http://www.emn.fr/x-info/coccinelle/)
@exists@
type T1,T2;
identifier E;
statement S,S1;
expression x1,x2,x3;
expression test;
int ret != 0;
  struct pci_dev *E;
  E = \(pci_get_slot\|pci_get_device\|pci_get_bus_and_slot\)(...);
  if (E == NULL) S
  if ((E = \(pci_get_slot\|pci_get_device\|pci_get_bus_and_slot\)(...)) == NULL) S
  ... when != pci_dev_put(...,(T1)E,...)
      when != if (E != NULL) { ... pci_dev_put(...,(T1)E,...); ...}
      when != x1 = (T1)E
      when != E = x3;
      when any
  if (E == NULL) S1
  if (test)
+   pci_dev_put(E);
    return;
+   pci_dev_put(E);
    return ret;
  if (test) {
    ... when != pci_dev_put(...,(T2)E,...)
        when != if (E != NULL) { ... pci_dev_put(...,(T2)E,...); ...}
        when != x2 = (T2)E
+   pci_dev_put(E);
    return;
+   pci_dev_put(E);
    return ret;
Signed-off-by: Julia Lawall
Cc: "David S. Miller"
Cc: "Antonino A. Daplas"
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 drivers/video/igafb.c | 5 +++++
 1 file changed, 5 insertions(+)
diff --git a/drivers/video/igafb.c b/drivers/video/igafb.c
index b87ea21..3a81060 100644
--- a/drivers/video/igafb.c
+++ b/drivers/video/igafb.c
@@ -400,6 +400,7 @@ int __init igafb_init(void)
         info = kzalloc(size, GFP_ATOMIC);
         if (!info) {
                 printk("igafb_init: can't alloc fb_info\n");
+		 pci_dev_put(pdev);
                 return -ENOMEM;
@@ -409,12 +410,14 @@ int __init igafb_init(void)
 	if ((addr = pdev->resource[0].start) == 0) {
                 printk("igafb_init: no memory start\n");
 		kfree(info);
 		return -ENXIO;
 	if ((info->screen_base = ioremap(addr, 1024*1024*2)) == 0) {
                 printk("igafb_init: can't remap %lx[2M]\n", addr);
 		kfree(info);
 		return -ENXIO;
@@ -449,6 +452,7 @@ int __init igafb_init(void)
                 printk("igafb_init: can't remap %lx[4K]\n", igafb_fix.mmio_start);
 		iounmap((void *)info->screen_base);
 		kfree(info);
 		return -ENXIO;
@@ -466,6 +470,7 @@ int __init igafb_init(void)
 		iounmap((void *)par->io_base);
 		iounmap(info->screen_base);
 		kfree(info);
 		return -ENOMEM;
