[POWERPC] arch/powerpc/sysdev: Add missing of_node_put
The functions of_find_compatible_node and of_find_node_by_type both
call of_node_get on their result.  So any error handling code
thereafter should call of_node_put(np).  This is taken care of in the
case where there is a goto out, but not when there is a direct return.
The function irq_alloc_host puts np into the returned structure, which is
stored in the global variable mpc8xx_pic_host, so the reference count
should be set for the lifetime of that variable.  The current solution ups
the reference count again in the argument to irq_alloc_host so that it can
be decremented on the way out.  This seems a bit unnecessary, and also
doesn't work in the case where irq_alloc_host fails, because then the
reference count only goes does by one, whereas it should go down by two.  A
better solution is to not increment the reference count in the argument to
irq_alloc_host and only decrement it on the way out in an error case.
The problem was found using the following semantic match.
(http://www.emn.fr/x-info/coccinelle/)
type T,T1,T2;
identifier E;
statement S;
expression x1,x2,x3;
int ret;
  T E;
* E = \(of_get_parent\|of_find_compatible_node\)(...);
  if (E == NULL) S
  ... when != of_node_put(...,(T1)E,...)
      when != if (E != NULL) { ... of_node_put(...,(T1)E,...); ...}
      when != x1 = (T1)E
      when != E = x3;
      when any
  if (...) {
    ... when != of_node_put(...,(T2)E,...)
        when != if (E != NULL) { ... of_node_put(...,(T2)E,...); ...}
        when != x2 = (T2)E
*   return;
*   return ret;
Signed-off-by: Julia Lawall
Cc: Stephen Rothwell
Cc: Benjamin Herrenschmidt
Cc: Kumar Gala
Signed-off-by: Andrew Morton
Signed-off-by: Paul Mackerras
 arch/powerpc/sysdev/mpc8xx_pic.c | 10 +++++++---
 1 file changed, 7 insertions(+), 3 deletions(-)
diff --git a/arch/powerpc/sysdev/mpc8xx_pic.c b/arch/powerpc/sysdev/mpc8xx_pic.c
index 0e74a4b..5d2d552 100644
--- a/arch/powerpc/sysdev/mpc8xx_pic.c
+++ b/arch/powerpc/sysdev/mpc8xx_pic.c
@@ -174,15 +174,19 @@ int mpc8xx_pic_init(void)
 		goto out;
 	siu_reg = ioremap(res.start, res.end - res.start + 1);
-	if (siu_reg == NULL)
-		return -EINVAL;
+	if (siu_reg == NULL) {
+		ret = -EINVAL;
+		goto out;
-	mpc8xx_pic_host = irq_alloc_host(of_node_get(np), IRQ_HOST_MAP_LINEAR,
+	mpc8xx_pic_host = irq_alloc_host(np, IRQ_HOST_MAP_LINEAR,
 					 64, &mpc8xx_pic_host_ops, 64);
 	if (mpc8xx_pic_host == NULL) {
 		printk(KERN_ERR "MPC8xx PIC: failed to allocate irq host!\n");
 		ret = -ENOMEM;
+		goto out;
+	return 0;
 out:
 	of_node_put(np);
BtrLinux
Privacy Overview
