Of_get_parent and of_find_compatible_node do a of_node_get, and thus a
corresponding of_code_put is needed in both the error case and the normal
return case.
The problem was found using the following semantic match.
(http://www.emn.fr/x-info/coccinelle/)
type T,T1,T2;
identifier E;
statement S;
expression x1,x2,x3;
int ret;
T E;
* E = \(of_get_parent\|of_find_compatible_node\)(...);
if (E == NULL) S
... when != of_node_put(...,(T1)E,...)
when != if (E != NULL) { ... of_node_put(...,(T1)E,...); ...}
when != x1 = (T1)E
when != E = x3;
when any
if (...) {
... when != of_node_put(...,(T2)E,...)
when != if (E != NULL) { ... of_node_put(...,(T2)E,...); ...}
when != x2 = (T2)E
* return;
* return ret;
Signed-off-by: Julia Lawall
Cc: Stephen Rothwell
Cc: Benjamin Herrenschmidt
Cc: Paul Mackerras
Cc: Kumar Gala
Signed-off-by: Andrew Morton
Signed-off-by: Paul Mackerras
arch/powerpc/platforms/82xx/mpc8272_ads.c | 3 +--
arch/powerpc/platforms/82xx/pq2fads.c | 3 +--
2 files changed, 2 insertions(+), 4 deletions(-)
diff --git a/arch/powerpc/platforms/82xx/mpc8272_ads.c b/arch/powerpc/platforms/82xx/mpc8272_ads.c
index 3fce6b3..7d30187 100644
--- a/arch/powerpc/platforms/82xx/mpc8272_ads.c
+++ b/arch/powerpc/platforms/82xx/mpc8272_ads.c
@@ -134,13 +134,12 @@ static void __init mpc8272_ads_setup_arch(void)
bcsr = of_iomap(np, 0);
+ of_node_put(np);
if (!bcsr) {
printk(KERN_ERR "Cannot map BCSR registers\n");
return;
- of_node_put(np);
clrbits32(&bcsr[1], BCSR1_RS232_EN1 | BCSR1_RS232_EN2 | BCSR1_FETHIEN);
setbits32(&bcsr[1], BCSR1_FETH_RST);
diff --git a/arch/powerpc/platforms/82xx/pq2fads.c b/arch/powerpc/platforms/82xx/pq2fads.c
index 68196e3..e1dceee 100644
--- a/arch/powerpc/platforms/82xx/pq2fads.c
+++ b/arch/powerpc/platforms/82xx/pq2fads.c
@@ -130,13 +130,12 @@ static void __init pq2fads_setup_arch(void)
+ of_node_put(np);
if (!bcsr) {
return;
- of_node_put(np);
/* Enable the serial and ethernet ports */
clrbits32(&bcsr[1], BCSR1_RS232_EN1 | BCSR1_RS232_EN2 | BCSR1_FETHIEN); |
+ of_node_put(np);
if (!bcsr) {
return;
- of_node_put(np);
+ of_node_put(np);
if (!bcsr) {
return;
- of_node_put(np);
