parisc: Use DEFINE_SPINLOCK
SPIN_LOCK_UNLOCKED is deprecated.  The following makes the change suggested
in Documentation/spinlocks.txt
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
declarer name DEFINE_SPINLOCK;
identifier xxx_lock;
- spinlock_t xxx_lock = SPIN_LOCK_UNLOCKED;
+ DEFINE_SPINLOCK(xxx_lock);
Signed-off-by: Julia Lawall
Signed-off-by: Kyle McMartin
 arch/parisc/kernel/pdc_cons.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/parisc/kernel/pdc_cons.c b/arch/parisc/kernel/pdc_cons.c
index ccb6809..1ff366c 100644
--- a/arch/parisc/kernel/pdc_cons.c
+++ b/arch/parisc/kernel/pdc_cons.c
@@ -52,7 +52,7 @@
 #include <linux/tty.h>
 #include <asm/pdc.h>		/* for iodc_call() proto and friends */
-static spinlock_t pdc_console_lock = SPIN_LOCK_UNLOCKED;
+static DEFINE_SPINLOCK(pdc_console_lock);
 static void pdc_console_write(struct console *co, const char *s, unsigned count)
BtrLinux
Privacy Overview
