Staging: go7007: introduce missing kfree
Error handling code following a kmalloc should free the allocated data.
The semantic match that finds the problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r exists@
local idexpression x;
statement S;
expression E;
identifier f,l;
position p1,p2;
expression *ptr != NULL;
if ((x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...)) == NULL) S
x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
when != if (...) { <+...x...+> }
x->f = E
return \(0\|<+...x...+>\|ptr\);
return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
Signed-off-by: Julia Lawall
drivers/staging/go7007/s2250-board.c | 1 +
1 file changed, 1 insertion(+)
diff --git a/drivers/staging/go7007/s2250-board.c b/drivers/staging/go7007/s2250-board.c
index a60e19c..d333ea2 100644
--- a/drivers/staging/go7007/s2250-board.c
+++ b/drivers/staging/go7007/s2250-board.c
@@ -167,6 +167,7 @@ static int write_reg(struct i2c_client *client, u8 reg, u8 value)
usb = go->hpi_context;
if (down_interruptible(&usb->i2c_lock) != 0) {
printk(KERN_INFO "i2c lock failed\n");
+ kfree(buf);
return -EINTR;
rc = go7007_usb_vendor_request(go, 0x55, dev_addr, |
+ kfree(buf);
return -EINTR;
