net/rxrpc/ar-peer.c: remove invalid reference to list iterator variable
Author: Julia Lawall <Julia.Lawall@lip6.fr>
If list_for_each_entry, etc complete a traversal of the list, the iterator
variable ends up pointing to an address at an offset from the list head,
and not a meaningful structure.  Thus this value should not be used after
the end of the iterator.  This seems to be a copy-paste bug from a previous
debugging message, and so the meaningless value is just deleted.
This problem was found using Coccinelle (http://coccinelle.lip6.fr/).
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 net/rxrpc/ar-peer.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/net/rxrpc/ar-peer.c b/net/rxrpc/ar-peer.c
index 2754f09..bebaa43 100644
--- a/net/rxrpc/ar-peer.c
+++ b/net/rxrpc/ar-peer.c
@@ -229,7 +229,7 @@ found_UDP_peer:
 	return peer;
 new_UDP_peer:
-	_net("Rx UDP DGRAM from NEW peer %d", peer->debug_id);
+	_net("Rx UDP DGRAM from NEW peer");
 	read_unlock_bh(&rxrpc_peer_lock);
 	_leave(" = -EBUSY [new]");
 	return ERR_PTR(-EBUSY);
BtrLinux
Privacy Overview
