drivers/isdn/mISDN/stack.c: remove invalid reference to list iterator variable
Author: Julia Lawall <Julia.Lawall@lip6.fr>
If list_for_each_entry, etc complete a traversal of the list, the iterator
variable ends up pointing to an address at an offset from the list head,
and not a meaningful structure. Thus this value should not be used after
the end of the iterator. The dereferences are just deleted from the
debugging statement.
This problem was found using Coccinelle (http://coccinelle.lip6.fr/).
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
drivers/isdn/mISDN/stack.c | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/isdn/mISDN/stack.c b/drivers/isdn/mISDN/stack.c
index 1a0ae44..5f21f62 100644
--- a/drivers/isdn/mISDN/stack.c
+++ b/drivers/isdn/mISDN/stack.c
@@ -135,8 +135,8 @@ send_layer2(struct mISDNstack *st, struct sk_buff *skb)
skb = NULL;
else if (*debug & DEBUG_SEND_ERR)
printk(KERN_DEBUG
- "%s ch%d mgr prim(%x) addr(%x) err %d\n",
- __func__, ch->nr, hh->prim, ch->addr, ret);
+ "%s mgr prim(%x) err %d\n",
+ __func__, hh->prim, ret);
out:
mutex_unlock(&st->lmutex); |
skb = NULL;
printk(KERN_DEBUG
out:
