net/rxrpc: Use an IS_ERR test rather than a NULL test
Author: Julien Brunel <brunel@diku.dk>
In case of error, the function rxrpc_get_transport returns an ERR
pointer, but never returns a NULL pointer. So after a call to this
function, a NULL test should be replaced by an IS_ERR test.
A simplified version of the semantic patch that makes this change is
as follows:
(http://www.emn.fr/x-info/coccinelle/)
@correct_null_test@
expression x,E;
statement S1, S2;
x =  rxrpc_get_transport(...)
<... when != x = E
if (
- x@p2 != NULL
+ ! IS_ERR ( x )
- x@p2 == NULL
+ IS_ERR( x )
S1
else S2
? x = E;
Signed-off-by: Julien Brunel
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 net/rxrpc/ar-accept.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/net/rxrpc/ar-accept.c b/net/rxrpc/ar-accept.c
index bdfb774..77228f2 100644
--- a/net/rxrpc/ar-accept.c
+++ b/net/rxrpc/ar-accept.c
@@ -100,7 +100,7 @@ static int rxrpc_accept_incoming_call(struct rxrpc_local *local,
 	trans = rxrpc_get_transport(local, peer, GFP_NOIO);
 	rxrpc_put_peer(peer);
-	if (!trans) {
+	if (IS_ERR(trans)) {
 		_debug("no trans");
 		ret = -EBUSY;
 		goto error;
BtrLinux
Privacy Overview
