IB/mad: Test ib_create_send_mad() return with IS_ERR(), not == NULL
Author: Julien Brunel <brunel@diku.dk>
In case of error, the function ib_create_send_mad() returns an ERR
pointer, but never returns a NULL pointer. So testing the return
value for error should be done with IS_ERR, not by comparing with
NULL.
A simplified version of the semantic patch that makes this change is
as follows:
(http://www.emn.fr/x-info/coccinelle/)
@correct_null_test@
expression x,E;
statement S1, S2;
x = ib_create_send_mad(...)
<... when != x = E
if (
- x@p2 != NULL
+ ! IS_ERR ( x )
- x@p2 == NULL
+ IS_ERR( x )
S1
else S2
? x = E;
Signed-off-by: Julien Brunel
Signed-off-by: Julia Lawall
Signed-off-by: Roland Dreier
drivers/infiniband/core/mad_rmpp.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/infiniband/core/mad_rmpp.c b/drivers/infiniband/core/mad_rmpp.c
index d0ef7d6..3af2b84 100644
--- a/drivers/infiniband/core/mad_rmpp.c
+++ b/drivers/infiniband/core/mad_rmpp.c
@@ -133,7 +133,7 @@ static void ack_recv(struct mad_rmpp_recv *rmpp_recv,
msg = ib_create_send_mad(&rmpp_recv->agent->agent, recv_wc->wc->src_qp,
recv_wc->wc->pkey_index, 1, hdr_len,
0, GFP_KERNEL);
- if (!msg)
+ if (IS_ERR(msg))
return;
format_ack(msg, (struct ib_rmpp_mad *) recv_wc->recv_buf.mad, rmpp_recv); |
0, GFP_KERNEL);
- if (!msg)
+ if (IS_ERR(msg))
return;
