net: Xilinx: fix error return code
Author: Julia Lawall <julia.lawall@lip6.fr>
Return a negative error code on failure.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier ret; expression e1,e2;
if (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/ethernet/xilinx/ll_temac_main.c   | 2 ++
 drivers/net/ethernet/xilinx/xilinx_emaclite.c | 1 +
 2 files changed, 3 insertions(+)
diff --git a/drivers/net/ethernet/xilinx/ll_temac_main.c b/drivers/net/ethernet/xilinx/ll_temac_main.c
index 9c2d91e..dbcbf0c 100644
--- a/drivers/net/ethernet/xilinx/ll_temac_main.c
+++ b/drivers/net/ethernet/xilinx/ll_temac_main.c
@@ -1043,6 +1043,7 @@ static int temac_of_probe(struct platform_device *op)
 	lp->regs = of_iomap(op->dev.of_node, 0);
 	if (!lp->regs) {
 		dev_err(&op->dev, "could not map temac regs.\n");
+		rc = -ENOMEM;
 		goto nodev;
@@ -1062,6 +1063,7 @@ static int temac_of_probe(struct platform_device *op)
 	np = of_parse_phandle(op->dev.of_node, "llink-connected", 0);
 	if (!np) {
 		dev_err(&op->dev, "could not find DMA node\n");
+		rc = -ENODEV;
 		goto err_iounmap;
diff --git a/drivers/net/ethernet/xilinx/xilinx_emaclite.c b/drivers/net/ethernet/xilinx/xilinx_emaclite.c
index 2485879..9d4ce38 100644
--- a/drivers/net/ethernet/xilinx/xilinx_emaclite.c
+++ b/drivers/net/ethernet/xilinx/xilinx_emaclite.c
@@ -1109,6 +1109,7 @@ static int xemaclite_of_probe(struct platform_device *ofdev)
 	res = platform_get_resource(ofdev, IORESOURCE_IRQ, 0);
 	if (!res) {
 		dev_err(dev, "no IRQ found\n");
+		rc = -ENXIO;
 		goto error;
BtrLinux
Privacy Overview
