myri10ge: fix error return code
Author: Julia Lawall <julia.lawall@lip6.fr>
Return a negative error code on failure.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier ret; expression e1,e2;
if (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
The patch also modifies the test of mgp->cmd to satisfy checkpatch.
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/ethernet/myricom/myri10ge/myri10ge.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/net/ethernet/myricom/myri10ge/myri10ge.c b/drivers/net/ethernet/myricom/myri10ge/myri10ge.c
index af09905..71af98b 100644
--- a/drivers/net/ethernet/myricom/myri10ge/myri10ge.c
+++ b/drivers/net/ethernet/myricom/myri10ge/myri10ge.c
@@ -4033,8 +4033,10 @@ static int myri10ge_probe(struct pci_dev *pdev, const struct pci_device_id *ent)
 	(void)pci_set_consistent_dma_mask(pdev, DMA_BIT_MASK(64));
 	mgp->cmd = dma_alloc_coherent(&pdev->dev, sizeof(*mgp->cmd),
 				      &mgp->cmd_bus, GFP_KERNEL);
-	if (mgp->cmd == NULL)
+	if (!mgp->cmd) {
+		status = -ENOMEM;
 		goto abort_with_enabled;
 	mgp->board_span = pci_resource_len(pdev, 0);
 	mgp->iomem_base = pci_resource_start(pdev, 0);
