Author: Julia Lawall <julia.lawall@lip6.fr>
Convert a call to init_timer and accompanying intializations of
the timer's data and function fields to a call to setup_timer.
A simplified version of the semantic match that fixes this problem is as
follows: (http://coccinelle.lip6.fr/)
expression t,f,d;
-init_timer(&t);
+setup_timer(&t,f,d);
-t.function = f;
-t.data = d;
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
drivers/net/ethernet/samsung/sxgbe/sxgbe_main.c | 10 ++++------
1 file changed, 4 insertions(+), 6 deletions(-)
diff --git a/drivers/net/ethernet/samsung/sxgbe/sxgbe_main.c b/drivers/net/ethernet/samsung/sxgbe/sxgbe_main.c
index 6984944..b6612d6 100644
--- a/drivers/net/ethernet/samsung/sxgbe/sxgbe_main.c
+++ b/drivers/net/ethernet/samsung/sxgbe/sxgbe_main.c
@@ -133,9 +133,8 @@ bool sxgbe_eee_init(struct sxgbe_priv_data * const priv)
return false;
priv->eee_active = 1;
- init_timer(&priv->eee_ctrl_timer);
- priv->eee_ctrl_timer.function = sxgbe_eee_ctrl_timer;
- priv->eee_ctrl_timer.data = (unsigned long)priv;
+ setup_timer(&priv->eee_ctrl_timer, sxgbe_eee_ctrl_timer,
+ (unsigned long)priv);
priv->eee_ctrl_timer.expires = SXGBE_LPI_TIMER(eee_timer);
add_timer(&priv->eee_ctrl_timer);
@@ -1009,10 +1008,9 @@ static void sxgbe_tx_init_coalesce(struct sxgbe_priv_data *priv)
struct sxgbe_tx_queue *p = priv->txq[queue_num];
p->tx_coal_frames = SXGBE_TX_FRAMES;
p->tx_coal_timer = SXGBE_COAL_TX_TIMER;
- init_timer(&p->txtimer);
+ setup_timer(&p->txtimer, sxgbe_tx_timer,
+ (unsigned long)&priv->txq[queue_num]);
p->txtimer.expires = SXGBE_COAL_TIMER(p->tx_coal_timer);
- p->txtimer.data = (unsigned long)&priv->txq[queue_num];
- p->txtimer.function = sxgbe_tx_timer;
add_timer(&p->txtimer);
return false;
