leds: Use setup_timer
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Convert a call to init_timer and accompanying intializations of
the timer's data and function fields to a call to setup_timer.
A simplified version of the semantic match that fixes this problem is as
follows: (http://coccinelle.lip6.fr/)
expression t,f,d;
-init_timer(&t);
+setup_timer(&t,f,d);
-t.function = f;
-t.data = d;
Signed-off-by: Julia Lawall
Signed-off-by: Bryan Wu
drivers/leds/led-class.c | 5 ++---
1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/drivers/leds/led-class.c b/drivers/leds/led-class.c
index dbeebac..291ca45 100644
--- a/drivers/leds/led-class.c
+++ b/drivers/leds/led-class.c
@@ -239,9 +239,8 @@ int led_classdev_register(struct device *parent, struct led_classdev *led_cdev)
INIT_WORK(&led_cdev->set_brightness_work, set_brightness_delayed);
- init_timer(&led_cdev->blink_timer);
- led_cdev->blink_timer.function = led_timer_function;
- led_cdev->blink_timer.data = (unsigned long)led_cdev;
+ setup_timer(&led_cdev->blink_timer, led_timer_function,
+ (unsigned long)led_cdev);
#ifdef CONFIG_LEDS_TRIGGERS
led_trigger_set_default(led_cdev); |
