mwifiex: fix comparison expression
Author: Andrzej Hajda <a.hajda@samsung.com>
To avoid underflows signed variables should be used in expression.
The problem has been detected using proposed semantic patch
scripts/coccinelle/tests/unsigned_lesser_than_zero.cocci [1].
[1]: http://permalink.gmane.org/gmane.linux.kernel/2038576
Signed-off-by: Andrzej Hajda
Acked-by: Amitkumar Karwar
Signed-off-by: David S. Miller
drivers/net/wireless/mwifiex/11n_rxreorder.c | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/net/wireless/mwifiex/11n_rxreorder.c b/drivers/net/wireless/mwifiex/11n_rxreorder.c
index 2906cd5..b3970a8 100644
--- a/drivers/net/wireless/mwifiex/11n_rxreorder.c
+++ b/drivers/net/wireless/mwifiex/11n_rxreorder.c
@@ -615,10 +615,10 @@ int mwifiex_11n_rx_reorder_pkt(struct mwifiex_private *priv,
((end_win > start_win) && ((seq_num > end_win) ||
(seq_num < start_win)))) {
end_win = seq_num;
- if (((seq_num - win_size) + 1) >= 0)
+ if (((end_win - win_size) + 1) >= 0)
start_win = (end_win - win_size) + 1;
else
- start_win = (MAX_TID_VALUE - (win_size - seq_num)) + 1;
+ start_win = (MAX_TID_VALUE - (win_size - end_win)) + 1;
mwifiex_11n_dispatch_pkt_until_start_win(priv, tbl, start_win);
end_win = seq_num;
else
