mmc: sdhci: Constify sdhci_ops structs where possible
Author: Lars-Peter Clausen <lars@metafoo.de>
Basically all drivers can have sdhci_ops struct const, but almost none do.
This patch constifies all sdhci_ops struct declarations where possible.
The patch was auto-generated with the following coccinelle semantic patch:
@r1@
identifier ops;
identifier fld;
ops.fld = ...;
@disable optional_qualifier@
identifier ops != r1.ops;
static
+const
struct sdhci_ops ops = { ... };
Signed-off-by: Lars-Peter Clausen
Acked-by: Shawn Guo
Signed-off-by: Chris Ball
 drivers/mmc/host/sdhci-bcm2835.c   | 2 +-
 drivers/mmc/host/sdhci-cns3xxx.c   | 2 +-
 drivers/mmc/host/sdhci-dove.c      | 2 +-
 drivers/mmc/host/sdhci-esdhc-imx.c | 2 +-
 drivers/mmc/host/sdhci-of-esdhc.c  | 2 +-
 drivers/mmc/host/sdhci-of-hlwd.c   | 2 +-
 drivers/mmc/host/sdhci-pci.c       | 2 +-
 drivers/mmc/host/sdhci-pltfm.c     | 2 +-
 drivers/mmc/host/sdhci-pxav2.c     | 2 +-
 drivers/mmc/host/sdhci-pxav3.c     | 2 +-
 drivers/mmc/host/sdhci-spear.c     | 2 +-
 drivers/mmc/host/sdhci-tegra.c     | 2 +-
 12 files changed, 12 insertions(+), 12 deletions(-)
diff --git a/drivers/mmc/host/sdhci-bcm2835.c b/drivers/mmc/host/sdhci-bcm2835.c
index 29e9e40..d49bc95 100644
--- a/drivers/mmc/host/sdhci-bcm2835.c
+++ b/drivers/mmc/host/sdhci-bcm2835.c
@@ -124,7 +124,7 @@ unsigned int bcm2835_sdhci_get_min_clock(struct sdhci_host *host)
 	return MIN_FREQ;
-static struct sdhci_ops bcm2835_sdhci_ops = {
+static const struct sdhci_ops bcm2835_sdhci_ops = {
 	.write_l = bcm2835_sdhci_writel,
 	.write_w = bcm2835_sdhci_writew,
 	.write_b = bcm2835_sdhci_writeb,
diff --git a/drivers/mmc/host/sdhci-cns3xxx.c b/drivers/mmc/host/sdhci-cns3xxx.c
index 15a936a..4fa26de 100644
--- a/drivers/mmc/host/sdhci-cns3xxx.c
+++ b/drivers/mmc/host/sdhci-cns3xxx.c
@@ -80,7 +80,7 @@ out:
 	host->clock = clock;
-static struct sdhci_ops sdhci_cns3xxx_ops = {
+static const struct sdhci_ops sdhci_cns3xxx_ops = {
 	.get_max_clock	= sdhci_cns3xxx_get_max_clk,
 	.set_clock	= sdhci_cns3xxx_set_clock,
diff --git a/drivers/mmc/host/sdhci-dove.c b/drivers/mmc/host/sdhci-dove.c
index b514f68..15e7803 100644
--- a/drivers/mmc/host/sdhci-dove.c
+++ b/drivers/mmc/host/sdhci-dove.c
@@ -83,7 +83,7 @@ static u32 sdhci_dove_readl(struct sdhci_host *host, int reg)
 	return ret;
-static struct sdhci_ops sdhci_dove_ops = {
+static const struct sdhci_ops sdhci_dove_ops = {
 	.read_w	= sdhci_dove_readw,
 	.read_l	= sdhci_dove_readl,
diff --git a/drivers/mmc/host/sdhci-esdhc-imx.c b/drivers/mmc/host/sdhci-esdhc-imx.c
index 68c301d..67d6dde 100644
--- a/drivers/mmc/host/sdhci-esdhc-imx.c
+++ b/drivers/mmc/host/sdhci-esdhc-imx.c
@@ -399,7 +399,7 @@ static int esdhc_pltfm_bus_width(struct sdhci_host *host, int width)
 	return 0;
-static struct sdhci_ops sdhci_esdhc_ops = {
+static const struct sdhci_ops sdhci_esdhc_ops = {
 	.read_l = esdhc_readl_le,
 	.read_w = esdhc_readw_le,
 	.write_l = esdhc_writel_le,
diff --git a/drivers/mmc/host/sdhci-of-esdhc.c b/drivers/mmc/host/sdhci-of-esdhc.c
index b98b919..5e68adc 100644
--- a/drivers/mmc/host/sdhci-of-esdhc.c
+++ b/drivers/mmc/host/sdhci-of-esdhc.c
@@ -230,7 +230,7 @@ static void esdhc_of_platform_init(struct sdhci_host *host)
 		host->quirks &= ~SDHCI_QUIRK_NO_BUSY_IRQ;
 	.read_l = esdhc_readl,
 	.read_w = esdhc_readw,
 	.read_b = esdhc_readb,
diff --git a/drivers/mmc/host/sdhci-of-hlwd.c b/drivers/mmc/host/sdhci-of-hlwd.c
index 7ea5c02..200a6a9 100644
--- a/drivers/mmc/host/sdhci-of-hlwd.c
+++ b/drivers/mmc/host/sdhci-of-hlwd.c
@@ -51,7 +51,7 @@ static void sdhci_hlwd_writeb(struct sdhci_host *host, u8 val, int reg)
 	udelay(SDHCI_HLWD_WRITE_DELAY);
-static struct sdhci_ops sdhci_hlwd_ops = {
+static const struct sdhci_ops sdhci_hlwd_ops = {
 	.read_l = sdhci_be32bs_readl,
 	.read_w = sdhci_be32bs_readw,
 	.read_b = sdhci_be32bs_readb,
diff --git a/drivers/mmc/host/sdhci-pci.c b/drivers/mmc/host/sdhci-pci.c
index 3dee22d..c1f0372 100644
--- a/drivers/mmc/host/sdhci-pci.c
+++ b/drivers/mmc/host/sdhci-pci.c
@@ -975,7 +975,7 @@ static void sdhci_pci_hw_reset(struct sdhci_host *host)
 	usleep_range(300, 1000);
-static struct sdhci_ops sdhci_pci_ops = {
+static const struct sdhci_ops sdhci_pci_ops = {
 	.enable_dma	= sdhci_pci_enable_dma,
 	.platform_bus_width	= sdhci_pci_bus_width,
 	.hw_reset		= sdhci_pci_hw_reset,
diff --git a/drivers/mmc/host/sdhci-pltfm.c b/drivers/mmc/host/sdhci-pltfm.c
index 3893fd6..cd0f1f6 100644
--- a/drivers/mmc/host/sdhci-pltfm.c
+++ b/drivers/mmc/host/sdhci-pltfm.c
@@ -44,7 +44,7 @@ unsigned int sdhci_pltfm_clk_get_max_clock(struct sdhci_host *host)
 EXPORT_SYMBOL_GPL(sdhci_pltfm_clk_get_max_clock);
-static struct sdhci_ops sdhci_pltfm_ops = {
+static const struct sdhci_ops sdhci_pltfm_ops = {
 #ifdef CONFIG_OF
diff --git a/drivers/mmc/host/sdhci-pxav2.c b/drivers/mmc/host/sdhci-pxav2.c
index eeb7d43..6a3f702 100644
--- a/drivers/mmc/host/sdhci-pxav2.c
+++ b/drivers/mmc/host/sdhci-pxav2.c
@@ -111,7 +111,7 @@ static int pxav2_mmc_set_width(struct sdhci_host *host, int width)
 	return 0;
-static struct sdhci_ops pxav2_sdhci_ops = {
+static const struct sdhci_ops pxav2_sdhci_ops = {
 	.get_max_clock = sdhci_pltfm_clk_get_max_clock,
 	.platform_reset_exit = pxav2_set_private_registers,
 	.platform_bus_width = pxav2_mmc_set_width,
diff --git a/drivers/mmc/host/sdhci-pxav3.c b/drivers/mmc/host/sdhci-pxav3.c
index a0cdbc5..5663a6e 100644
--- a/drivers/mmc/host/sdhci-pxav3.c
+++ b/drivers/mmc/host/sdhci-pxav3.c
@@ -167,7 +167,7 @@ static int pxav3_set_uhs_signaling(struct sdhci_host *host, unsigned int uhs)
 	return 0;
-static struct sdhci_ops pxav3_sdhci_ops = {
+static const struct sdhci_ops pxav3_sdhci_ops = {
 	.platform_reset_exit = pxav3_set_private_registers,
 	.set_uhs_signaling = pxav3_set_uhs_signaling,
 	.platform_send_init_74_clocks = pxav3_gen_init_74_clocks,
diff --git a/drivers/mmc/host/sdhci-spear.c b/drivers/mmc/host/sdhci-spear.c
index c6ece0b..8d28334 100644
--- a/drivers/mmc/host/sdhci-spear.c
+++ b/drivers/mmc/host/sdhci-spear.c
@@ -36,7 +36,7 @@ struct spear_sdhci {
 /* sdhci ops */
 	/* Nothing to do for now. */
diff --git a/drivers/mmc/host/sdhci-tegra.c b/drivers/mmc/host/sdhci-tegra.c
index f8ac50c..45048d1 100644
--- a/drivers/mmc/host/sdhci-tegra.c
+++ b/drivers/mmc/host/sdhci-tegra.c
@@ -147,7 +147,7 @@ static int tegra_sdhci_buswidth(struct sdhci_host *host, int bus_width)
 	return 0;
-static struct sdhci_ops tegra_sdhci_ops = {
+static const struct sdhci_ops tegra_sdhci_ops = {
 	.get_ro     = tegra_sdhci_get_ro,
 	.read_l     = tegra_sdhci_readl,
 	.read_w     = tegra_sdhci_readw,
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
