can: mcp251x: Remove redundant spi driver bus initialization
Author: Lars-Peter Clausen <lars@metafoo.de>
In ancient times it was necessary to manually initialize the bus field of an
spi_driver to spi_bus_type. These days this is done in spi_driver_register() so
we can drop the manual assignment.
The patch was generated using the following coccinelle semantic patch:
identifier _driver;
struct spi_driver _driver = {
.driver = {
- .bus = &spi_bus_type,
Signed-off-by: Lars-Peter Clausen
Acked-by: Marc Kleine-Budde
Signed-off-by: Marc Kleine-Budde
drivers/net/can/mcp251x.c | 1 -
1 file changed, 1 deletion(-)
diff --git a/drivers/net/can/mcp251x.c b/drivers/net/can/mcp251x.c
index f32b9fc..05e93e8 100644
--- a/drivers/net/can/mcp251x.c
+++ b/drivers/net/can/mcp251x.c
@@ -1207,7 +1207,6 @@ MODULE_DEVICE_TABLE(spi, mcp251x_id_table);
static struct spi_driver mcp251x_can_driver = {
.driver = {
.name = DEVICE_NAME,
.owner = THIS_MODULE,
.driver = {
