mmc: card: mmc_test: Simplify a trivial if-return sequence
Author: Fabio Estevam <fabio.estevam@freescale.com>
Simplify a trivial if-return sequence. Possibly combine with a
preceding function call.
The semantic patch that makes this change is available
in scripts/coccinelle/misc/simple_return.cocci.
More information about semantic patching is available at
http://coccinelle.lip6.fr/
Signed-off-by: Fabio Estevam
Signed-off-by: Ulf Hansson
 drivers/mmc/card/mmc_test.c | 100 +++++++-------------------------------------
 1 file changed, 15 insertions(+), 85 deletions(-)
diff --git a/drivers/mmc/card/mmc_test.c b/drivers/mmc/card/mmc_test.c
index 53b7413..5e90b3f 100644
--- a/drivers/mmc/card/mmc_test.c
+++ b/drivers/mmc/card/mmc_test.c
@@ -268,8 +268,6 @@ static int mmc_test_wait_busy(struct mmc_test_card *test)
 static int mmc_test_buffer_transfer(struct mmc_test_card *test,
 	u8 *buffer, unsigned addr, unsigned blksz, int write)
-	int ret;
 	struct mmc_request mrq = {0};
 	struct mmc_command cmd = {0};
 	struct mmc_command stop = {0};
@@ -292,11 +290,7 @@ static int mmc_test_buffer_transfer(struct mmc_test_card *test,
 	if (data.error)
 		return data.error;
-	ret = mmc_test_wait_busy(test);
-	if (ret)
-		return ret;
-	return 0;
+	return mmc_test_wait_busy(test);
 static void mmc_test_free_mem(struct mmc_test_mem *mem)
@@ -994,11 +988,7 @@ static int mmc_test_basic_write(struct mmc_test_card *test)
 	sg_init_one(&sg, test->buffer, 512);
-	ret = mmc_test_simple_transfer(test, &sg, 1, 0, 1, 512, 1);
-	if (ret)
-		return ret;
-	return 0;
+	return mmc_test_simple_transfer(test, &sg, 1, 0, 1, 512, 1);
 static int mmc_test_basic_read(struct mmc_test_card *test)
@@ -1012,44 +1002,29 @@ static int mmc_test_basic_read(struct mmc_test_card *test)
-	ret = mmc_test_simple_transfer(test, &sg, 1, 0, 1, 512, 0);
-	if (ret)
-		return ret;
-	return 0;
+	return mmc_test_simple_transfer(test, &sg, 1, 0, 1, 512, 0);
 static int mmc_test_verify_write(struct mmc_test_card *test)
-	int ret;
 	struct scatterlist sg;
-	ret = mmc_test_transfer(test, &sg, 1, 0, 1, 512, 1);
-	if (ret)
-		return ret;
-	return 0;
+	return mmc_test_transfer(test, &sg, 1, 0, 1, 512, 1);
 static int mmc_test_verify_read(struct mmc_test_card *test)
-	int ret;
-	ret = mmc_test_transfer(test, &sg, 1, 0, 1, 512, 0);
-	if (ret)
-		return ret;
-	return 0;
+	return mmc_test_transfer(test, &sg, 1, 0, 1, 512, 0);
 static int mmc_test_multi_write(struct mmc_test_card *test)
-	int ret;
 	unsigned int size;
@@ -1066,16 +1041,11 @@ static int mmc_test_multi_write(struct mmc_test_card *test)
 	sg_init_one(&sg, test->buffer, size);
-	ret = mmc_test_transfer(test, &sg, 1, 0, size/512, 512, 1);
-	if (ret)
-		return ret;
-	return 0;
+	return mmc_test_transfer(test, &sg, 1, 0, size/512, 512, 1);
 static int mmc_test_multi_read(struct mmc_test_card *test)
-	int ret;
 	unsigned int size;
@@ -1092,11 +1062,7 @@ static int mmc_test_multi_read(struct mmc_test_card *test)
-	ret = mmc_test_transfer(test, &sg, 1, 0, size/512, 512, 0);
-	if (ret)
-		return ret;
-	return 0;
+	return mmc_test_transfer(test, &sg, 1, 0, size/512, 512, 0);
 static int mmc_test_pow2_write(struct mmc_test_card *test)
@@ -1263,11 +1229,7 @@ static int mmc_test_xfersize_write(struct mmc_test_card *test)
 	if (ret)
 		return ret;
-	ret = mmc_test_broken_transfer(test, 1, 512, 1);
-	if (ret)
-		return ret;
-	return 0;
+	return mmc_test_broken_transfer(test, 1, 512, 1);
 static int mmc_test_xfersize_read(struct mmc_test_card *test)
@@ -1278,11 +1240,7 @@ static int mmc_test_xfersize_read(struct mmc_test_card *test)
 	if (ret)
 		return ret;
-	ret = mmc_test_broken_transfer(test, 1, 512, 0);
-	if (ret)
-		return ret;
-	return 0;
+	return mmc_test_broken_transfer(test, 1, 512, 0);
 static int mmc_test_multi_xfersize_write(struct mmc_test_card *test)
@@ -1296,11 +1254,7 @@ static int mmc_test_multi_xfersize_write(struct mmc_test_card *test)
 	if (ret)
 		return ret;
-	ret = mmc_test_broken_transfer(test, 2, 512, 1);
-	if (ret)
-		return ret;
-	return 0;
+	return mmc_test_broken_transfer(test, 2, 512, 1);
 static int mmc_test_multi_xfersize_read(struct mmc_test_card *test)
@@ -1314,48 +1268,33 @@ static int mmc_test_multi_xfersize_read(struct mmc_test_card *test)
 	if (ret)
 		return ret;
-	ret = mmc_test_broken_transfer(test, 2, 512, 0);
-	if (ret)
-		return ret;
-	return 0;
+	return mmc_test_broken_transfer(test, 2, 512, 0);
 #ifdef CONFIG_HIGHMEM
 static int mmc_test_write_high(struct mmc_test_card *test)
-	int ret;
 	sg_init_table(&sg, 1);
 	sg_set_page(&sg, test->highmem, 512, 0);
-	if (ret)
-		return ret;
-	return 0;
 static int mmc_test_read_high(struct mmc_test_card *test)
-	int ret;
-	if (ret)
-		return ret;
-	return 0;
 static int mmc_test_multi_write_high(struct mmc_test_card *test)
-	int ret;
 	unsigned int size;
@@ -1373,16 +1312,11 @@ static int mmc_test_multi_write_high(struct mmc_test_card *test)
 	sg_set_page(&sg, test->highmem, size, 0);
-	if (ret)
-		return ret;
-	return 0;
 static int mmc_test_multi_read_high(struct mmc_test_card *test)
-	int ret;
 	unsigned int size;
@@ -1400,11 +1334,7 @@ static int mmc_test_multi_read_high(struct mmc_test_card *test)
-	if (ret)
-		return ret;
-	return 0;
 #else
BtrLinux
Privacy Overview
