mmc: host: mxcmmc: Simplify a trivial if-return sequence
Author: Fabio Estevam <fabio.estevam@freescale.com>
Simplify a trivial if-return sequence. Possibly combine with a
preceding function call.
The semantic patch that makes this change is available
in scripts/coccinelle/misc/simple_return.cocci.
More information about semantic patching is available at
http://coccinelle.lip6.fr/
Signed-off-by: Fabio Estevam
Signed-off-by: Ulf Hansson
drivers/mmc/host/mxcmmc.c | 6 +-----
1 file changed, 1 insertion(+), 5 deletions(-)
diff --git a/drivers/mmc/host/mxcmmc.c b/drivers/mmc/host/mxcmmc.c
index 317d709..d110f9e 100644
--- a/drivers/mmc/host/mxcmmc.c
+++ b/drivers/mmc/host/mxcmmc.c
@@ -605,11 +605,7 @@ static int mxcmci_push(struct mxcmci_host *host, void *_buf, int bytes)
mxcmci_writel(host, cpu_to_le32(tmp), MMC_REG_BUFFER_ACCESS);
- stat = mxcmci_poll_status(host, STATUS_BUF_WRITE_RDY);
- if (stat)
- return stat;
- return 0;
+ return mxcmci_poll_status(host, STATUS_BUF_WRITE_RDY);
static int mxcmci_transfer_data(struct mxcmci_host *host) |
- if (stat)
- return stat;
- return 0;
