MIPS: pci-ar71xx: Consolidate chained IRQ handler install/remove
Author: Thomas Gleixner <tglx@linutronix.de>
Chained irq handlers usually set up handler data as well. We now have
a function to set both under irq_desc->lock. Replace the two calls
with one.
Search and conversion was done with coccinelle.
Reported-by: Russell King
Signed-off-by: Thomas Gleixner
Cc: Julia Lawall
Cc: linux-mips@linux-mips.org
Cc: LKML
Cc: Jiang Liu
Patchwork: https://patchwork.linux-mips.org/patch/10696/
Signed-off-by: Ralf Baechle
 arch/mips/pci/pci-ar71xx.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/mips/pci/pci-ar71xx.c b/arch/mips/pci/pci-ar71xx.c
index 283157f..ad35a5e 100644
--- a/arch/mips/pci/pci-ar71xx.c
+++ b/arch/mips/pci/pci-ar71xx.c
@@ -312,8 +312,8 @@ static void ar71xx_pci_irq_init(struct ar71xx_pci_controller *apc)
 		irq_set_chip_data(i, apc);
-	irq_set_handler_data(apc->irq, apc);
-	irq_set_chained_handler(apc->irq, ar71xx_pci_irq_handler);
+	irq_set_chained_handler_and_data(apc->irq, ar71xx_pci_irq_handler,
+					 apc);
 static void ar71xx_pci_reset(void)
BtrLinux
Privacy Overview
