MIPS: jz4740: Consolidate chained IRQ handler install/remove
Author: Thomas Gleixner <tglx@linutronix.de>
Chained irq handlers usually set up handler data as well. We now have
a function to set both under irq_desc->lock. Replace the two calls
with one.
Search and conversion was done with coccinelle.
Reported-by: Russell King
Signed-off-by: Thomas Gleixner
Cc: Julia Lawall
Cc: linux-mips@linux-mips.org
Cc: LKML
Cc: Jiang Liu
Patchwork: https://patchwork.linux-mips.org/patch/10695/
Signed-off-by: Ralf Baechle
arch/mips/jz4740/gpio.c | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/mips/jz4740/gpio.c b/arch/mips/jz4740/gpio.c
index 54c80d4..77df160 100644
--- a/arch/mips/jz4740/gpio.c
+++ b/arch/mips/jz4740/gpio.c
@@ -423,8 +423,8 @@ static void jz4740_gpio_chip_init(struct jz_gpio_chip *chip, unsigned int id)
chip->base = ioremap(JZ4740_GPIO_BASE_ADDR + (id * 0x100), 0x100);
chip->irq = JZ4740_IRQ_INTC_GPIO(id);
- irq_set_handler_data(chip->irq, chip);
- irq_set_chained_handler(chip->irq, jz_gpio_irq_demux_handler);
+ irq_set_chained_handler_and_data(chip->irq,
+ jz_gpio_irq_demux_handler, chip);
gc = irq_alloc_generic_chip(chip->gpio_chip.label, 1, chip->irq_base,
chip->base, handle_level_irq); |
