[media] tuners/tda18271: Replace memcpy with struct assignment
Author: Ezequiel Garcia <elezegarcia@gmail.com>
This kind of memcpy() is error-prone. Its replacement with a struct
assignment is prefered because it's type-safe and much easier to read.
Found by coccinelle. Hand patched and reviewed.
Tested by compilation only.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier struct_name;
struct struct_name to;
struct struct_name from;
expression E;
-memcpy(&(to), &(from), E);
+to = from;
Signed-off-by: Peter Senna Tschudin
Signed-off-by: Ezequiel Garcia
Signed-off-by: Mauro Carvalho Chehab
drivers/media/tuners/tda18271-maps.c | 6 ++----
1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/drivers/media/tuners/tda18271-maps.c b/drivers/media/tuners/tda18271-maps.c
index fb881c6..b62e925 100644
--- a/drivers/media/tuners/tda18271-maps.c
+++ b/drivers/media/tuners/tda18271-maps.c
@@ -1290,13 +1290,11 @@ int tda18271_assign_map_layout(struct dvb_frontend *fe)
switch (priv->id) {
case TDA18271HDC1:
priv->maps = &tda18271c1_map_layout;
- memcpy(&priv->std, &tda18271c1_std_map,
- sizeof(struct tda18271_std_map));
+ priv->std = tda18271c1_std_map;
break;
case TDA18271HDC2:
priv->maps = &tda18271c2_map_layout;
- memcpy(&priv->std, &tda18271c2_std_map,
+ priv->std = tda18271c2_std_map;
break;
default:
ret = -EINVAL; |
switch (priv->id) {
case TDA18271HDC1:
break;
case TDA18271HDC2:
break;
default:
ret = -EINVAL;
