[media] staging: media: omap4iss: fix handling platform_get_irq result
Author: Andrzej Hajda <a.hajda@samsung.com>
The function can return negative value.
The problem has been detected using proposed semantic patch
scripts/coccinelle/tests/assign_signed_to_unsigned.cocci [1].
[1]: http://permalink.gmane.org/gmane.linux.kernel/2046107
Signed-off-by: Andrzej Hajda
Signed-off-by: Mauro Carvalho Chehab
 drivers/staging/media/omap4iss/iss.c | 5 +++--
 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/drivers/staging/media/omap4iss/iss.c b/drivers/staging/media/omap4iss/iss.c
index 9bfb725..0b03cb7 100644
--- a/drivers/staging/media/omap4iss/iss.c
+++ b/drivers/staging/media/omap4iss/iss.c
@@ -1440,12 +1440,13 @@ static int iss_probe(struct platform_device *pdev)
 		 iss_reg_read(iss, OMAP4_ISS_MEM_ISP_SYS1, ISP5_REVISION));
 	/* Interrupt */
-	iss->irq_num = platform_get_irq(pdev, 0);
-	if (iss->irq_num <= 0) {
+	ret = platform_get_irq(pdev, 0);
+	if (ret <= 0) {
 		dev_err(iss->dev, "No IRQ resource\n");
 		ret = -ENODEV;
 		goto error_iss;
+	iss->irq_num = ret;
 	if (devm_request_irq(iss->dev, iss->irq_num, iss_isr, IRQF_SHARED,
 			     "OMAP4 ISS", iss)) {
BtrLinux
Privacy Overview
